Sam just shared a new tutorial: "How to Use Bluetooth Modules"
So we’ve taken a look at what Bluetooth is in our Introduction to Bluetooth tutorial, and hopefully, you’ve found our Choosing a Bluetooth Module For Your Project tutorial useful in deciding which Bluetooth module is right for your p…
Hi there,
I’m having issues with getting the AT commands working.
I have added a button to the module and it enters AT mode as expected. Since I’m using an Arduino Due I don’t need to use SoftwareSerial, but can instead use Serial1. The tutorial doesn’t explain how to wire the module to the Arduino, but I have connected RXD to TX1, TXD to RX1, Vcc to 5V, and GND to GND. I get ERROR:(0)
everytime I enter AT to the serial monitor.
I am also confused by which baud rates I should be using (the first code in the tutorial uses two different rates).
This is my code, taking into account Serial1 instead of SoftwareSerial
void setup()
Serial.begin(9600);
Serial1.begin(38400);
pinMode(22, OUTPUT);
digitalWrite (22, HIGH);
void loop()
if (Serial1.available())
Serial.write(Serial1.read());
if (Serial.available())
Serial1.write(Serial.read());
There has been a development!
Typing ‘AT’ into the serial monitor gives ‘ERROR:(0)’. But if I type ‘AT+VERSION?’ it successfully supplies the version and also replies ‘OK’. If after that I type ‘AT’, it replies ‘OK’. So essentially it works to ask for another AT command before asking ‘AT’ directly.
I’m not sure why this is the case. I think the code above might be useful for others trying to use the Due with HC-05, so is good to keep up there. My wiring is correct also. In relation to Baud rate: using serial monitor 2900 and Bluetooth 38400 works, but so does using 38400 for both.
If the device is doing automatic baud rate detection (which your comment about working OK with different baud rates implies) then the first few characters of any session will be lost as the device tries to detect the correct baud raqte to use. So perhaps it’s not the ‘AT’ that doesn’t work, but the first few characters whatever they are.
