Alex9562 just shared a new project: "IOT Shed Part 2"
If you haven’t already seen it, check out part 1 of this project. it has all the background info in it. And if you haven’t got one yet, get yourself a particle photon, they are great
This part of the project was hooking the particle photons up to a very simple web page that would let me remotely check the status of the systems and controll them as I see fit. From here on it will help if you know a little of html, css and java-script! Also, I’m no expert so there may be a better way of doing things so use of the following code is at your own risk.
