3D Printed Case for GlowBit 8x8 LED Matrix + ESP32
I’ve had one of those little 8x8 GlowBit LED matrix PCBs sitting in a box for over a year, along with a spare ESP32 and finally got around to assembling it and loading WLED using the guide.
After checking it worked, I had a bunch of wires everywhere so I decided this needed a case. I made a clip-together one which is a super tight fit but works pretty good for me at least.
My plan for this little box is to hookup WLED to home assistant and have it display small 8x8 emojis or something - not decided yet
glowbit_demo
Download the case from https://www.printables.com/model/1902612-glowbit-8x8-case-for-esp32 if you like :slight_smile:
Hey @Geoff726654,
I’ve been debating how I was going to house my 8x8 GlowBit, but I think I’m going to take advantage of your printables design.
Fantastic work!
Thanks! Please post a make if on printables if it works :slight_smile:
Nice work… looks really good.
I have been playing with the defuser for a while now on several projects.
On first effeort I printed the grid both sides and face in a white. I mostly liked it as it allowed some color to bleed into the next pixel, which in theory should be good for a kinda anti-alias. My next attempt was a white face with a black grid. This blocks all the side bleed and I feel gives a sharper image.
Note: I also prefer to add some tinted acrylic to the front. This darkens the entire thing down a little, but gives more “black” pixels.
Please note: I am not saying there is anything wrong here, just some feed back if you are still playing to give some idea on things to try. Most of this is very much an end user preference.
an example of a 32x32 grid.
Sorry not the best image; just wanted to show the results of some of my testing/playing.
That looks really cool! I had similar idea about just having a flat surface and letting the light do its own anti-aliasing but this would mean a large surface only .2mm thick so the grid is also to add strength. For this build, I wanted something simple to print without needing other materials. I think even printing it in black might improve it.
For the moment I moved on to my other half finished projects unless anyone needs a tiny adjustment doing. Next up for this one for me is getting it to do something useful in home assistant.
Yeah I tried that big fail :slight_smile: the black (PLA) I had even at .1mm was as good as a total blackout. The white/smooth gave the best results from my testing. I tried a translucent/clearish pla, but it was not even. I ended up on the white.
I have an ams, so it was really just, print white face then as soon as the grid started, swap over the the black.
the acrylic really helps (in my opinion), but the challange is to get the bits you need at the right size. Most places want to sell you a full or 1/2 sheet. For me thats ok as I am cutting my own on the CO2 Laser; so was happy to by a sheet (cut the size that fits into my laser).
Looks fantastic! Where did you print it from?
Thanks! its off a Prusa MK4S with 0.6mm nozzle. Filament was white polymaker panchroma PLA and STL files are on printables.com with link above. Let me know if it works :slight_smile:
