Barometer alert system - thresholds
I knocked up a simple weather monitor today using an ESP32S and a BME280 sensor and I thought the neopixel on it could be used for a visual alert for a falling barometer. It’s in a very simple form with no web server and it just outputs sensor values to a serial terminal and flashes the neopixel at the moment.
So I’m after some input on setting the threshold values for a falling barometer. I’ve never really been interested in this sort of thing so I just threw in some arbitrary values to test my code. I have it running the neopixel to display two alert levels right now but I’ll probably add a few more with some more complex logic when I develop it a bit more.
The first alert level is set to flash the neopixel blue 5 times in cycles when the pressure drops more than 5 hPA in an hour (this is planned to be a chance of rain alert).
The second alert level is set to flash the neopixel red 5 times in cycles when the pressure drops more than 10 hPa in an hour (this is planned to be a strong chance of rain alert).
The neopixel is set to cycle through a range of colours constantly if an alert threshold isn’t crossed in a 1 hour period. So this will be a visual no warning condition.
So what are some approximate pressure drops that could be expected if there is a chance of rain or a high chance of rain so I can dial my threshold levels in?
Also is a 1 hour sample period appropriate or would a longer or shorter sample period be more suitable?
Any input would be appreciated.
I’ve done a similar analysis on historical changes in Air Density for particular places. The Weather sites such as the BOM and Weatherzone have all the data you need. Try this site and pick a location. Much of the data is free, but if you pay a small subscription there’s large collections of it available. You could pick a historical rapid weather change and note how rapidly the parameters vary.
See: Rathmines Weather Forecast | Today's Local Weather Forecast
Use your ESP32 to log pressure readings over several days or weeks. This will help establish realistic thresholds for your specific environment.
Thanks for the input guys.
The idea came about after a conversation I had with a fisherman at a Stockton boat ramp on the weekend where he mentioned that a barometer can be useful to predict when fish are likely to go the on bite.
A websearch turned up some interesting info about fish and how a falling barometer can stimulate them to feed and then when the pressure drops enough they tend to stop biting. So I thought I’d combine that idea with a weather alert system and mount it on my kitchen window where my neighbours can see it. That way my next door neighbour will have a visual alert too and his wife will know if it’s a good idea to hang clothes on the clothes line. I plan to ditch the serial output and use a 1602 LCD display to turn it into standalone device when I get a chance.
Code if anyone is interested, it could use a few tweaks in the control loop to give it a bit more accuracy but this what I’m starting with.
import machine
import time
import bme280
from neopixel import NeoPixel
import uasyncio as asyncio
# Define SDA and SCL pins
SDA_PIN = 8  # ESP32 S
SCL_PIN = 9  # ESP32 S
# Initialise I2C
i2c = machine.I2C(0, scl=machine.Pin(SCL_PIN), sda=machine.Pin(SDA_PIN))
# Initialise BME280
bme = bme280.BME280(i2c=i2c)
# Initialise NeoPixel
NEOPIXEL_PIN = 48
num_pixels = 1  # Number of NeoPixels
np = NeoPixel(machine.Pin(NEOPIXEL_PIN), num_pixels)
# Variables to track pressure and timing
previous_pressure = None
pressure_drop_threshold_5hPa = 5
pressure_drop_threshold_10hPa = 10
check_interval = 3600  # 1 hour in seconds
display_interval = 30  # 30 seconds for displaying data
led_timeout = 10800  # 3 hours in seconds
# Function to turn fade the NeoPixel LED in cycles
async def fade_colors():
    while True:
        for r in range(256):  # Red to Yellow
            np[0] = (r, 255 - r, 0)  # Fade from Red to Yellow
            np.write()
            await asyncio.sleep(0.01)
        for g in range(256):  # Yellow to Green
            np[0] = (255 - g, g, 0)  # Fade from Yellow to Green
            np.write()
        for b in range(256):  # Green to Cyan
            np[0] = (0, 255 - b, b)  # Fade from Green to Cyan
            np.write()
        for r in range(256):  # Cyan to Blue
            np[0] = (0, r, 255 - r)  # Fade from Cyan to Blue
            np.write()
        for g in range(256):  # Blue to Magenta
            np[0] = (r, 0, g)  # Fade from Blue to Magenta
            np.write()
        for r in range(256):  # Magenta to Red
            np[0] = (255 - r, 0, 255)  # Fade from Magenta to Red
            np.write()
# Function to flash the NeoPixel LED in blue
async def flash_blue():
    for _ in range(5):  # Flash 5 times
        np[0] = (0, 0, 255)  # Set colour to blue
        np.write()
        await asyncio.sleep(0.5)
        np[0] = (0, 0, 0)  # Turn off
        np.write()
# Function to flash the NeoPixel LED in red
async def flash_red():
        np[0] = (255, 0, 0)  # Set colour to red
        np.write()
        np.write()
# Function to read sensor data
async def read_sensor_data():
    global previous_pressure
    while True:
        temperature, pressure, humidity = bme.read_temperature(), bme.read_pressure(), bme.read_humidity()
        pressure_hPa = pressure / 25600
        if previous_pressure is None:
            previous_pressure = pressure_hPa
        else:
            pressure_drop = previous_pressure - pressure_hPa
            if pressure_drop > pressure_drop_threshold_10hPa:
                await flash_red()
            elif pressure_drop > pressure_drop_threshold_5hPa:
                await flash_blue()
        await asyncio.sleep(60)  # Wait for 60 seconds before the next read
# Function to display data
async def display_data():
    while True:
        print("Temperature: {:.1f} °C".format(temperature / 100))
        print("Humidity: {:.1f} %".format(humidity / 1024))
        print("Pressure: {:.1f} hPa".format(pressure_hPa))
        await asyncio.sleep(display_interval)  # Wait for 30 seconds before the next display
# Main function to run tasks concurrently
async def main():
    # Start reading sensor data, displaying data, and fading colours concurrently
    await asyncio.gather(
        read_sensor_data(),
        display_data(),
        fade_colors()  # Start fading colors in parallel
# Run the main function
try:
    asyncio.run(main())
except KeyboardInterrupt:
    print("Program stopped.")
I polished that code up a bit yesterday and added a 1602 display. The control loop has been modified to try to smooth out some of the fluctuations in barometric pressure and some very basic error handling has been added.
The barometric pressure remained quite stable at the time of testing, so I haven’t had the opportunity to the threshold values. It functions quite well as a basic weather station with an LCD display and a neopixel Led that cycles through a range of colours but as I said I haven’t seen a large enough change in barometric pressure to test the alert functionality of the neopixel.
Here’s the latest incarnation of the code.
import machine
import time
import BME280
from lcd_api import LcdApi
from i2c_lcd import I2cLcd
from time import sleep
I2C_ADDR = 0x27
totalRows = 2
totalColumns = 16
SDA_PIN = 8  # ESP32 S3
SCL_PIN = 9  # ESP32 S3
# Initialise I2C
# Initialise BME280
bme = BME280.BME280(i2c=i2c)
# Initialise lcd
lcd = I2cLcd(i2c, I2C_ADDR, totalRows, totalColumns)
NEOPIXEL_PIN = 48
pressure_drop_threshold_2hPa = 2 #(adjust threshold for local conditions)
pressure_drop_threshold_4hPa = 4 #(adjust threshold for local conditions)
pressure_drop_threshold_6hPa = 6 #(adjust threshold for local conditions)
check_interval = 600  # 10  minutes in seconds
lcd_update_interval = 10 # 10 seconds between lcd updates
led_timeout = 3600  # 1 hour in seconds
pressure_readings = []
flash_active = False
# Shared data structure for sensor readings
sensor_data = {
    'temperature': None,
    'pressure': None,
    'humidity': None
# Function to fade the NeoPixel LED in cycles
async def fade_colours():
    while True:
        if flash_active:  # Check if a flash is active
            await asyncio.sleep(0.1)  # Wait briefly before checking again
            continue  # Skip fading if flashing is active
            np.write()
            await asyncio.sleep(0.01)  # Allow other tasks to run
            np.write()
            np.write()
            np.write()
            np.write()
            np.write()
# Function to flash the NeoPixel LED in blue until led_timeout is reached
    global flash_active
    flash_active = True  # Set the flag to indicate flashing is active
    start_time = time.time()  # Record the start time
    while time.time() - start_time < led_timeout:  # Continue until led_timeout is reached
        np.write()
        await asyncio.sleep(0.5)  # Flash on
        np.write()
        await asyncio.sleep(0.5)  # Flash off
    flash_active = False  # Reset the flag when done
# Function to flash the NeoPixel LED in green
async def flash_green():
    global flash_active
        np[0] = (0, 255, 0)  # Set colour to blue
        np.write()
        np.write()
    global flash_active
        np[0] = (255, 0, 0)  # Set colour to blue
        np.write()
        np.write()
    global previous_pressure, pressure_readings, sensor_data  # Declare as global
    while True:
        try:
            temperature = bme.read_temperature() / 100  # Convert to Celsius
            pressure = bme.read_pressure() / 25600  # Convert to hPa
            humidity = bme.read_humidity() / 1024  # Convert to percentage
            # Update shared sensor data
            sensor_data['temperature'] = temperature
            sensor_data['pressure'] = pressure
            sensor_data['humidity'] = humidity
            # Store the last four pressure readings
            pressure_readings.append(pressure)
            if len(pressure_readings) > 4:
                pressure_readings.pop(0)  # Keep only the last four readings
            # Calculate the average of the last four readings
            if len(pressure_readings) == 4:
                average_pressure = sum(pressure_readings) / len(pressure_readings)
                pressure_drop = previous_pressure - average_pressure if previous_pressure is not None else 0
               # Debugging print statements
                print(f"Pressure Drop: {pressure_drop:.2f} hPa")
                print(f"Current Pressure: {pressure:.2f} hPa")
                print(f"Average Pressure: {average_pressure:.2f} hPa")
                # Trigger LED functions based on the average pressure drop
                if pressure_drop > pressure_drop_threshold_6hPa:
                    print("Alert triggered: Pressure drop exceeds 6 hPa")
                    await flash_red()
                elif pressure_drop > pressure_drop_threshold_4hPa:
                    print("Alert triggered: Pressure drop exceeds 4 hPa")
                    await flash_green()
                elif pressure_drop > pressure_drop_threshold_2hPa:
                    print("Alert triggered: Pressure drop exceeds 2 hPa")
                    await flash_blue()
                    await flash_red()
                    await flash_green()
                    await flash_blue()
        except Exception as e:
            print("Error reading sensor data:", e)
        await asyncio.sleep(check_interval)  # Wait for the check interval before the next read
    while True:
        try:
            # Use shared sensor data
            print("Temperature: {:.1f} °C".format(sensor_data['temperature']))
            print("Humidity: {:.1f} %".format(sensor_data['humidity']))
            print("Pressure: {:.1f} hPa".format(sensor_data['pressure']))
            print("Error displaying data:", e)
# Function to update the LCD with sensor data
async def update_lcd():
    while True:
        try:
            lcd.clear()
            lcd.move_to(0, 0)
            lcd.putstr("Temp: {:.1f}C".format(sensor_data['temperature']))
            lcd.move_to(0, 1)
            lcd.putstr("Humidity: {:.1f}%".format(sensor_data['humidity']))
            await asyncio.sleep(5)
            lcd.move_to(0, 0)
            lcd.putstr("Barom: {:.1f}hPa".format(sensor_data['pressure']))
            print("Error updating LCD:", e)
        await asyncio.sleep(lcd_update_interval)
async def main():
    # Start reading sensor data, displaying data, update lcd and fade colours concurrently
        read_sensor_data(),
        display_data(),
        update_lcd(),
        asyncio.create_task(fade_colours())#  # Start fading colours in parallel
try:
    asyncio.run(main())
Edited to remove a line of blocking code that was preventing the LED flash alerts in the update_lcd function & to add some debug information to the serial output. Everything seems to be working now but it still hasn’t been tested for long enough to evaluate the sensitivity response of the pressure drop thresholds. It’s still using some arbitrary threshold values.
Hi Todd,
What a fun project. I often use barometers to measure altitude and vertical velocity. I also run into issues surrounding thresholds, my testing is easier though. I agree with @lia262073, you may need to let it run and record data for a while to determine the values.
Your code is looking good too, I can’t wait to see what the finished project looks like!
So I got it running with a bare bones HTML webpage to display the sensor data without any CSS voodoo or other bells and whistles. I wanted to run the web server on one core and the main code on the other but it seems like the uasyncio module in the firmware on the micropython website is missing a few key functions, so I just added the web server as another async function and it all seems to work well.
With the web server active the limitations of the power supply on the dev board have become apparent. Now the LCD is showing a dip in voltage which is happening in sync with the webpage update cycle which shows a barely noticeable drop in luminosity at each update.
Maybe I could smooth that out with a small cap across 5V and ground pins but a better solution would probably be to use an external power supply. I can live with it as it’s barely noticeable but it could annoy some people.
This is the last incarnation of the code with a web server and web page.
import machine
import time
import BME280
import network
import socket
I2C_ADDR = 0x27
totalRows = 2
totalColumns = 16
# Initialise I2C
# Initialise BME280
# Initialise lcd
NEOPIXEL_PIN = 48
pressure_drop_threshold_1hPa = 1
pressure_drop_threshold_3hPa = 3
sensor_data = {
    'pressure': None,
    'humidity': None
# Function to start the web server
async def web_server():
    addr_info = socket.getaddrinfo('0.0.0.0', 80)
    for addr in addr_info:
        try:
            s = socket.socket()
            s.bind(addr[4])  # Use addr[4] which is the (ip, port) tuple
            s.listen(1)
            print("Web server running on http://<your-esp32-ip>")
            break
        except OSError as e:
            print(f"Failed to bind to {addr[4]}: {e}")
    while True:
        cl, addr = s.accept()
        # print('Client connected from', addr)
        request = cl.recv(1024)
        if request:
            # print("Request:", request)
            # Generate HTML response
            html = f"""
            <!DOCTYPE html>
            <html>
            <head>
                <center>
                <title>Sensor Data</title>
                <meta charset="UTF-8">
                <meta http-equiv="refresh" content="10">
            </head>
            <body>
                <h1>Sensor Data</h1>
                <p>Temperature: {sensor_data['temperature']:.1f} &deg;C</p>
                <p>Humidity: {sensor_data['humidity']:.1f} %</p>
                <p>Pressure: {sensor_data['pressure']:.1f} hPa</p>
            </body>
            </html>
            cl.send('HTTP/1.0 200 OK\r\nContent-type: text/html\r\n\r\n')
            cl.send(html)
        else:
             print("No request received.")
        cl.close()  # Ensure the client connection is closed
    while True:
        if flash_active:  # Check if a flasmicropython variablesh is active
            np.write()
            np.write()
            np.write()
            np.write()
            np[0] = (0, g, 255 - g)  # Fade from Blue to Magenta
            np.write()
            np.write()
    global flash_active
        np.write()
        np.write()
    global flash_active
        np.write()
        np.write()
    global flash_active
        np.write()
        np.write()
    while True:
        try:
            # Log the sensor data in CSV format
            print(f"{temperature},{humidity},{pressure}")  # Send data in CSV format
                if pressure_drop > pressure_drop_threshold_3hPa:
                    await flash_red()
                    await flash_green()
                elif pressure_drop > pressure_drop_threshold_1hPa:
                    await flash_blue()
    while True:
        try:
    last_update_time = time.time()
    display_duration = 5  # Duration to display each reading
    display_state = 'temperature'  # Initial state
    while True:
        try:
            current_time = time.time()
            if current_time - last_update_time >= display_duration:
                lcd.clear()
                if display_state == 'temperature':
                    lcd.move_to(0, 0)
                    lcd.move_to(0, 1)
                    display_state = 'pressure'  # Switch to pressure next
                else:
                    lcd.move_to(0, 0)
                    lcd.move_to(0, 1)
                    display_state = 'temperature'  # Switch back to temperature next
                last_update_time = current_time  # Reset the timer
            await asyncio.sleep(0.1)  # Yield control to other tasks
async def main():
    # Connect to Wi-Fi (make sure to replace with your credentials)
    ssid = 'Your wifi network name'
    password = 'Your wifi password'
    wlan = network.WLAN(network.STA_IF)
    wlan.active(True)
    wlan.connect(ssid, password)
    while not wlan.isconnected():
        print("Connecting to WiFi...")
        await asyncio.sleep(1)
    print("Connected to WiFi:", wlan.ifconfig())
        read_sensor_data(),
        display_data(),
        update_lcd(),
        fade_colours(),
        web_server()  # Start the web server
try:
    asyncio.run(main())
The code sans the web server for a standalone device. Anyone dabbling in asynchronous coding for other projects might find it useful.
import machine
import time
import BME280
I2C_ADDR = 0x27
totalRows = 2
totalColumns = 16
# Initialise I2C
# Initialise BME280
# Initialise lcd
NEOPIXEL_PIN = 48
pressure_drop_threshold_1hPa = 1 #(changed for led flash test)
pressure_drop_threshold_2hPa = 2 #(changed for led flash test)
pressure_drop_threshold_3hPa = 3 #(changed for led flash test)
sensor_data = {
    'pressure': None,
    'humidity': None
    while True:
            np.write()
            np.write()
            np.write()
            np.write()
            np[0] = (0, 255 - g, g)  # Fade from Blue to Magenta
            np.write()
            np.write()
    global flash_active, current_flash_color
    flash_active = True
    current_flash_color = "Blue"  # Set the current flash color
        np[0] = (0, 0, 255)
        np.write()
        np[0] = (0, 0, 0)
        np.write()
    current_flash_color = None  # Reset the current flash color
    flash_active = True
    current_flash_color = "Green"  # Set the current flash color
        np[0] = (0, 255, 0)
        np.write()
        np[0] = (0, 0, 0)
        np.write()
    flash_active = True
    current_flash_color = "Red"  # Set the current flash color
        np[0] = (255, 0, 0)
        np.write()
        np[0] = (0, 0, 0)
        np.write()
    while True:
        try:
                    await flash_red()
                    await flash_green()
                    await flash_blue()
    while True:
        try:
# Function to update lcd
    while True:
        try:
                lcd.clear()
                    lcd.move_to(0, 0)
                    lcd.move_to(0, 1)
                else:
                    lcd.move_to(0, 0)
                    lcd.move_to(0, 1)
async def main():
        read_sensor_data(),
        display_data(),
        update_lcd(),
try:
    asyncio.run(main())
Hi Todd
If this is noticeable it is on the border line of giving trouble. Maybe not now but you could pretty well guarantee it at the worst possible moment later (Murphy’s Law, or Henry who thinks Murphy is a super optimist). Up your power system to something suitable now and save headaches.
