Best Way to Log Data from Multiple I2C Sensors with Raspberry Pi Pico
Hi everyone,
I’m working on a data logging project using the Raspberry Pi Pico and I need to collect readings from multiple I2C sensors specifically a BME280 (for temp/humidity/pressure), an MPU6050, and an OLED display. The challenge I’m facing is occasional data collisions or missed readings, especially when trying to log data in real-time to an SD card using SPI.
Has anyone worked with a similar setup? Would using a dedicated I2C multiplexer (like TCA9548A) help, or is there a better software-level fix to handle timing issues? Also curious if CircuitPython handles this smoother than MicroPython?
Appreciate any tips or best practices from folks who’ve juggled multiple I2C devices on a Pico.
References:
https://www.theengineeringprojects.com/2022/03/introduction-to-raspberry-pi-pico.html
https://learn.adafruit.com/circuitpython-on-raspberrypi-pico
https://projects.raspberrypi.org/en/projects/getting-started-with-the-pico
Hi @Aria291175
Welcome to the forum!
Using a multiplexer isn’t necessary unless you’re trying to run multiple sensors using the same address.
Circuitpython is a derivative of Micropython, using it really won’t make any sort of difference in terms of performance, if performance is an issue I’d recommend using C++ or C if you’re really needing to get everything possible out of an MCU.
I’d say the simplest option would be to slow things down and add a delay between readings, 0.1 second should be fine but you can experiment with it. You may also get results from slowing down the I2C bus frequency.
The BME280 and MPU6050 may both try to communicate at the same time or you may be polling too rapidly. I think it is better to use an I2C multiplexer.
