# Bluetooth issues with 8BitDo SN30pro on Rasp Pi 4 with Retropie
**URL:** <https://forum.core-electronics.com.au/t/bluetooth-issues-with-8bitdo-sn30pro-on-rasp-pi-4-with-retropie/10119>\
**Category:** Support\
**Created:** [10 May 2021 06:05 UTC](https://forum.core-electronics.com.au/t/bluetooth-issues-with-8bitdo-sn30pro-on-rasp-pi-4-with-retropie/10119 "2021-05-10T06:05:23Z")\
**Showing post:** 16
**Author:** ![Oliver](https://yyz2.discourse-cdn.com/flex028/user_avatar/forum.core-electronics.com.au/oliver/32/3315_2.png) [@Oliver](https://forum.core-electronics.com.au/u/Oliver)\
**Post date:** [12 May 2021 07:25 UTC](https://forum.core-electronics.com.au/t/bluetooth-issues-with-8bitdo-sn30pro-on-rasp-pi-4-with-retropie/10119/16 "2021-05-12T07:25:31Z")
Hi All,
I was able to pair both an SN30 Pro+ and a Pro 2 without issue - I’m not sure what the issue may be that you’re all facing 🤔
The procedure I followed was:
- Grab a preloaded RetroPie SD card from our shelf stock
- Boot it up on a Pi 4 8GB
- Setup a USB keyboard
- Open up the Bluetooth configuration
- Press and Hold Start + Y (Switch mode) and then immediately hit Enter on "Register and Connect to Bluetooth Device
- Quickly tap down the manual to select Pro Controller, then hit Enter
- Hit enter again on the first option - “DisplayYesNo”
- Taken back to the Bluetooth Configuration main menu.
- Controller is paired and immediately works to move around in the bluetooth configuration menu with the analogue sticks and dpad
Possible things that may make a difference:
- I’ve got my controller right next to my Pi to ensure a good signal while pairing
- I’m keeping an eye on my controller to make sure it doesn’t power down while searching for a connection/bluetooth devices
- My controller batteries are fully charged
_[View the full topic](https://forum.core-electronics.com.au/t/bluetooth-issues-with-8bitdo-sn30pro-on-rasp-pi-4-with-retropie/10119)._
