# Can the LED on PiicoDev sensor be turned off?
**URL:** <https://forum.core-electronics.com.au/t/can-the-led-on-piicodev-sensor-be-turned-off/11255>\
**Category:** Product Questions\
**Created:** [3 September 2021 11:41 UTC](https://forum.core-electronics.com.au/t/can-the-led-on-piicodev-sensor-be-turned-off/11255 "2021-09-03T11:41:05Z")\
**Showing post:** 2
**Author:** ![Spookee](https://yyz2.discourse-cdn.com/flex028/user_avatar/forum.core-electronics.com.au/spookee/32/4915_2.png) [@Spookee](https://forum.core-electronics.com.au/u/Spookee)\
**Post date:** [4 September 2021 00:47 UTC](https://forum.core-electronics.com.au/t/can-the-led-on-piicodev-sensor-be-turned-off/11255/2 "2021-09-04T00:47:50Z")
Hi Jono,
There is a trace on the rear of the PCB you can cut to disable the power LED (and solder pads to bridge if you want to reenable it later). @Michael mentioned it in another PiicoDev thread I’ve linked below.
> [@PiicoDev MPU-6050 motion sensor - error](https://forum.core-electronics.com.au/t/piicodev-mpu-6050-motion-sensor-error/10695/14):
> I regret not checking the forums over the weekend! There is a less destructive way to disable the Power LED - Cut the jumper labelled PWR LED on the rear side of the board: [image] A hobby knife or razor works well. Be careful not to cut anywhere outside the pill-shaped outline. You can solder across this jumper to re-enable the power LED later. I’ll update product listings to ensure this feature is more obvious.
_[View the full topic](https://forum.core-electronics.com.au/t/can-the-led-on-piicodev-sensor-be-turned-off/11255)._
