Chipset in Pimoroni SATA Hard Drive to USB Adapter SKU: ADP001
Can someone please confirm what is the chipset used in Pimoroni SATA Hard Drive to USB Adapter SKU: ADP001 - check using lsusb to see the chipset? Does it support UASP on RP4? What read/write speeds do you get using this with SSD drives connected to USB3.0 ports? Thanks!
Hi Tony,
I just fired up my Pi with on attached an here’s a screenshot of the output:
I wasn’t able to confirm UASP or the speeds as I’m not sure how to test (and my SATA SSD is quite old).
If you have a surefire way of doing some tests let me know and I can try them!
