Core Electronics Forum
DE2120 Scanner
Hi Matt,
Finding a ready to go long-range RFID setup may be easier said than done. The setup would be akin to the anti-theft gates at supermarkets which is quite high powered and cumbersome. Here is an article explaining those anti theft gates if you really want to go down that path:
In any case, you could get the RFID tags and a basic reader and if you wanted to update to a longer distance reader in the future you could after you had gotten the system working. The RFID tags we sell aren’t waterproof but it shouldn’t be too hard to waterproof the ICs. Here are a few examples:
Is it possible to incorporate the use of spreadsheets with RFID tags?
I would like to be able to write RFID tags with the same technology
Yes absolutely. The openpyxl library isn’t specific to the barcode scanner it is a library for the coding language Python. You will need to code them to work together (obviously) but that shouldn’t be that different from coding in the barcode scanner.
Do you have the products in stock yet? So I can start the project
Hi Matthew,
We’ve currently got some on the way to us right now. If you place an order now we can get one on the road to you as soon as they arrive.
FYI, our lead times and stock levels are live on our product pages. If something’s in stock here in Newcastle it’ll say so here :slight_smile:
