EEPROM problem
Hi
I am trying to save a 2 variables i and j in EEPROM, I can change those values by buttons, but after disconnecting the power both values are not saved and on LCD I have i=0 and j=0.
Please help me to fix the problem.
#include <LiquidCrystal.h>
#include <EEPROM.h>
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
int i;
int ovfi;
int j;
int ovfj;
void setup()
  pinMode(PB6, INPUT_PULLDOWN);
  pinMode(PB9, INPUT_PULLDOWN);
  pinMode(PB5, INPUT_PULLDOWN);
  pinMode(PB8, INPUT_PULLDOWN);
  lcd.begin(16, 2);
  EEPROM.read(256);
  EEPROM.read(0);
void loop()
  ovfi = 3000 - i;
  if (digitalRead(PB8) == HIGH)
    if (i < 3000)
      i++;
  if (digitalRead(PB5) == HIGH)
    if (i > 0)
      i--;
  EEPROM.write(256, i);
  ovfi = 3000 - j;
  if (digitalRead(PB9) == HIGH)
    if (i < 3000)
      j++;
  if (digitalRead(PB6) == HIGH)
    if (i > 0)
      j--;
  EEPROM.write(0, i);
  lcd.setCursor(0, 0);
  lcd.print(EEPROM.read(256));
  lcd.setCursor(0, 1);
  lcd.print(EEPROM.read(0));
Have run your code and suggest the following changes.
Initialize variables when they are declared.
int i = 0;
int ovfi = 0;
int j = 0;
int ovfj = 0;
The EEPROM values are read in setup() but not assigned to any variable, so when the code runs i and j are zero every time.
i = EEPROM.read(256);
j = EEPROM.read(0);
In the j loop you use ovfi not ovfj (I think this is what you intend)
also the if statements refer to i not j but increment or decrement j
PS I didnt have an LCD but after the changes the EEPROM values are updated correctly.
Thanks, it is working
Great fix James!
