Elsema FMR-212 Version 4
I work at Currumbin Wildlife Sanctuary. We have a small gauge train track carrying passengers around and have several signal boxes around the park. We need 4 x Elsema FMR 212 circuit boards. It seems that they are discontinued. Any suggestions? Would a FMR201-R be the same?
My email is aingram@cws.org.au
Hey there, @Angela334024, and welcome to the forum. Glad to have you here. ,
I would not be able to say for certain, but I would not think that the FMR201-R is interchangeable with the FMR212. From some research, it looks like the R is advertised as a replacement for the FMR201 instead. Using it might require reworking the signal box’s connections or control circuitry, rather than simply swapping boards.
If possible, could you please share:
  • A clear photo of an existing board, including its model, frequency markings and connections?
  • The model of the transmitter that operates it?
  • The board’s supply voltage, if it’s documented?
  • Whether the receiver operates the signal lights directly or feeds another controller?
Hi Jane,
They are similar but don’t have the switches at the bottom to change the frequency, so we can’t use them. I think we might have to completely change our system because I can’t find the old boards anywhere.
Here are the answers I have found (my colleague just came back from holiday to assist me)
· A clear photo of an existing board, including its model, frequency markings and connections?
· The model of the transmitter that operates it? ELSEMA FMT-301
· The board’s supply voltage, if it’s documented? 12V
· Whether the receiver operates the signal lights directly or feeds another controller? Its actually a noise signal (buzzer) and light, it has 12V battery back up. It does not feed another controller, there are 12 of these. 3 of them also operate water solenoids.
(attachments)
Thanks for sending that information through.
At this point, I’d suggest contacting Elsema directly with that photo and the transmitter model. They may have a supported replacement or repair option that preserves the current system, which could save you a lot of headaches compared with replacing the whole setup.
Thank you so much!
