FSDU motion motor
I’m looking for an up and down motion motor to create a movement on the header card, Would you be able to help me with this, we need the motor run with batteries, so it can last at least 3-4 months at the store?
Hi Dewi,
Welcome to the forum :grinning:
I’m not familiar with the abbreviation FSDU so I’m not sure what the header card in your question is a part of. Can you provide a bit more context about what you need motors to control and what existing system these motors will be a part of?
Hi Trent,
The idea is to use 2 different cut out pieces from corrugate cardboard to create a moving display, the back panel will be static, and the cut-out panel will move up and down. The motor has to be light enough to be attached to the back of the cardboard, which run with Battery.
