what is the maximum pressure the Polymer Lithium Ion Battery (LiPo) 3.7V 1100mAh can withstand?
Hi Ishman
Do you mean pressure from the outside? Like being submerged in water or inside some sort of pressure tank.
I think you will be pretty lucky to find this sort of spec published. This sort of info may be available in a research lab of some description but personally I have not seen it.
There may be some specs re batteries that operate at high altitudes but that would refer to pressure from the inside I would think.
Good luck anyway and keep us posted on findings. Interested.
Yup, I meant submerged in a tank because I wanted to use this in an underwater device. Thank you for your reply though!
Water tank/swimming pool/ any sort of water body
That clears that up. As I said I have never seen that spec published although you may find it if you investigate on the manufacturers web site. You may have to look at other places than China though.
Got it! Thank you so much for your help bob! Appreciate it
