This is a placeholder topic for “Magnetic Third-Hand Kit” comments.
If you need an extra pair of hands (or three!) to help with the delicate, detailed work, you will appreciate this magnetic third-hand kit…
Read moreThis is a placeholder topic for “Magnetic Third-Hand Kit” comments.
Read moreWhat are those four spring loaded spikes on the front of the base about?
If you are soldering to a PCB then it will likely have mounting holes. So the spikes can be aligned with the mounting holes and the board placed squarely on top. The pins are tapered so they fit any size mounting holes.
