Heyya all, new tutorial out, "Make Fused Filament Prints Perfectly Clear"
No Layer Lines = Transparency! So this will go through the process of drastically improving your 3D printed part transparency when they are made from Polymaker Polysmooth Transparent Filament or other PVB materials. The magic of this process occurs because PVB is soluble in alcohol. This means after a liberal and repeated misting of alcohol over the model you can hide all the layer lines and smooth out the final piece. I go through the whole process and capture the stages along the way.
