I’m devising a new wearable costume involving MCUs and have recently been thinking a lot about ESD and how static electricity could affect the build - I’m hoping the community can steer me in the right direction.
The idea would be to use a Molle vest as a base, then attach devices like MCUs, LEDs, switches, bells, whitles, etc - anything really - to panels made from ABS which are then velcroed to the base vest. Panels might then be wired to one another using chunky USB plugs. I understand that the vest itself is made from a synthetic material, so moving around in it alone might be generating static electricty, and on top of that there’s the action of pulling velcro apart which may also generate a charge.
Obviously I don’t want to be frying my electronics or myself while using something like this, so I wanted to get an idea of what options I have at my disposal. Some questions come to mind:
How worried should I be in general about damaging the components via ESD? People seem to be putting MCUs into wearable costumes all the time without thinking too much about this sort of thing - but then maybe it’s down to the materials used.
Am I better off ditching the synthetic vest and using a different material as a base - like canvas?
Does certain footwear mitigate static build up while wearing the vest?
Is static build up ok so long as it’s not discharged into something delecate (like an MCU), or something metallic?
I’ve read that there are certain components that can be used to mitigate ESD events, like around USB connections and so on. Would these work in an environment with a floating ground, ie a wearable costume?
Can I potentially ground myself before touching anything on the vest to mitigate any risk?
Is there anything I can do to the vest to dissipate any charge that might be building up?
Am I missing any other obvious options? Eg would wearing rubber wash-up gloves mitigate the risk?
I will leave the real answers to those that know the subject much better then me.
As to “…People seem to be putting MCUs into wearable costumes all the time without thinking too much about this sort of thing…” Yeah, but I think that comes down to “hobby v ideal”.
It MAY work and you may never have an issue, but then again, it could fry something every time you use it.
There are plenty of times a project will work perfect on the work bench, then fail in the real world (over time).
At the very least I would ensure some level of protection on an “pin” that enters or leaves the project box. (e.g. connected to the button, feeds the led, supplies power).
How you do this may vary (seeking others input here); e.g.you dont want to add the wrong protection and create a new problem
Hi Michael, James
I think that these days there are some ICs around with built in static protection. But th be on the safe side ALL ICs should be handled on a static mat with a wrist strap attached to the mat.
There is a good reason why ICs are shipped in static proof bags.
Try and stay away from stuff like Nylon and perspex. We once had dealings with several cabinet racks and the spec was to have transparent doors. Due to static problems we had to use glass as perspex can generate 20kV to 30kV pretty readily. The glass was much heavier but we had to live with that. No option.
Even the humble plastic (???) hair comb gan generate quite a voltage when used. See how it attracts a bit of paper.
30kV seems like a lot but is usually harmless to us mere mortals as the impedance is very high and so the current is minuscule. We were up a TV transmitting tower once during storm conditions and it was no problem drawing about a 15mm spark from the work platform rail to a finger on your hand. No real danger but we abandoned work for the day as lightning strikes can be something else again. Pretty safe inside the structure but not a very pleasant experience.
If you want reliability down the track a bit then just be careful and play it safe. If a component is in doubt, replace it. This will pay dividends long term.
Wearable electronics are a well established Maker field. There’s entire lines dedicated to working them, the most prominent being the LilyPad. It’s specifically to be sewn into clothing. It’s probably going to be the blest place to start for mixing clothing and electronics.
That being said, ESD can still be an issue, if generally more concerning for the electronics than the wearer. I’d probably focus more on enclosing the electronics rather than trying to eliminate static altogether. @Michael99645’s point about connections entering and leaving each enclosure is a good starting point. Although staying away from synthetic fabrics and materials like Velcro, would probably be a wise move.
