i recently purchased a Raspberry Pi Pico 2H and a ZY-60 Breadboard. it just arrived today - and i happily tore open the packaging and began building, only to be immediately distraught by the pins of the Pico being misaligned with the breadboard. i’ve been trying for a while and it’s not going in.
can someone give me advice on how i could resolve this??
Hi
Welcome.
If I had just read the text I would have said you are somehow mistaken. But after seeing the pic I am not so sure.
the Pico would almost certainly have a hole pitch of 2.54mm for the header pins. This by the way is a global standard and derives from the old 0.1 inch grid used for PCB design. The mounting holes might fit the multiple of 2.54mm spacing but might (read probably won’t) be on the same grid as the header. pins.
However over 20 pins there seems to be nearly half a hole space error.
I believe that somehow you have a breadboard with a hole pitch of 2.5mm as is becoming common with some connectors these days. Somebody has decided that 2.54mm is too cumbersome and standardised on 2.5mm instead. Almost get away with this up to about 4 pins but anything over this gets embarrassing.
to illustrate the difference 2.54mm x 19 (there are 19 spaces between pins) = 48.26mm while 2.5mm x 19 = 47.5. A difference of 0.76mm which looks like about your error here.
Solution: Chuck that bread board in the s…t bin and purchase a “proper” bread board from another supplier. Stay away from the very low cost versions or you might have a contact problem later on if you are going to use these header pins. These pins are up at about maximum size for these contacts and over a short time the female contacts will no longer accept a “normal” size component leg reliably.
You could verify this by carefully measure the distance over 20 pins and I think you will find I am correct.
Edited. “1.16” above changed to 0.76. Don’t know how I made that mistake.
Hi again
I just checked. I have one of these breadboards ov the same size. Not sure of the actual part number but it looks exactly the same as the ZY-60 as on Core product page. I have had mine for few years now and I just offered up a length of header strip.
Aligns over the 30 pins perfectly
Measure the hole centres over the 30 pins. This should be 73.66mm. If your board measures 72.5mm it would indicate a 2.5mm pitch which is incorrect for this item. Measuring over the whole 30 pins will make the error greater and easier to spot.
I note Core stock this item and if you purchased from them they might like to check the remaining stock. I don’t think you are the first raise this scenario. I think I have seen this complaint before.
Just noticed. Core breadboard is white mine is transparent.
Hey there, @bread_board, and welcome to the forum. Glad to have you here.
These breadboards are regularly used with your board, although the fit can be snug. @Robert93820’s measurement check is useful, but a slight apparent misalignment doesn’t necessarily mean the hole pitch is wrong.
I’d line up both rows of pins over the holes with the board straddling the centre channel, then apply gentle, even downward pressure. Don’t not push one end fully in first or it can cause misalignment. A little insertion resistance is normal, but don’t force it if the pins are catching on the plastic or bending.
Hi Jane
I don’t believe I am reading this. What is so hard about getting vernier calibers or a good steel rule aid measuring over 30 holes.
This sort of thing is not completely unknown. A couple of years ago I purchased a proto board from Jaycar and when I went to fit a length of pins I found the pitch to be 2.5mm. I had not seen that happen before but it did on that occasion.
Measure it instead of pussyfooting around and playing like a butcher.. Insertion may be normal due to pin size but misalignment is anything but normal.
Hi Jane, bread_board
This thread seems to have gone very quiet.
I just had another look at the pic bread_board supplied and noticed something that could be significant.
Have a close look at the 1 to 30 screen print in relation to the actual holes. I know the board is not exactly at right angles to the camera and you can get some lens distortion but the holes and print are on the same plane so comparison is I think valid.
You will note the number “1” is aligned pretty centrally with the hole axis while the number “29” is nearly half a hole longer.
Almost like the screen print is a pitch of 2.54mm and the actual holes are slightly smaller, like 2.5 maybe.
I think this might help clarify my earlier observation re this board having a hole pitch of 2.5mm instead of 2.54mm.
As a matter of interest has any body carried out the suggested measurement yet or are you all going to continue trying to fit a square peg into a round hole as the saying goes.
The ZY-60 is our budget breadboard, “cheap and cheerful” as its product page puts it, and its pitch runs a little under 2.54mm.
Bob’s 0.76mm is cumulative, though. With the Pico centred, the end pins are only about 0.38mm out, and breadboards are a friction fit: the sprung contacts take up that much offset. We use these with Picos all the time, and it’s a snug fit, not a no-fit. I in fact have one of these breadboards that I use for basic testing on my desk day by day with a Pico 2 W installed in it.
That’s why Jane’s advice is the right approach. Line up both rows and press evenly. Push one end in first and the full 0.76mm ends up at the other end.
So it’s less a square peg in a round hole and more a snug one. That said, you get what you pay for, so if you want a tighter-tolerance board, see our professional-grade breadboards.
Hi Blayden
Sounds like you endorse the butchers approach. Just as well you are not subject to any sort of QA system or it would have been thrown out the door. Possibly with you following.
You had better leave that Pico plugged into that board as you might have just about destroyed at least the end female sockets by now.
Having got that off my chest I thoroughly endorse the use of the better quality boards as the one you have linked. looks like a far better product. At least the screen print lines up with the holes through the entire length. The quality as expected lines up with the price but what the hell. For an extra $6 or so you will save a lot of heartache. I could never understand why Core, having establishes some sort of a reputation for quality, would stock both grades of essentially the same product.
Actually I did not know until now that the better grade board was stocked. I just searched for “ZY 60” and only the inferior (read cheaper) one came up along with a smaller one.
PS. If you look closely at that photo at the top of this thread you will see that Pico pin 1 ia at the left edge of the plastic hole, pins 7, 8 and 9 seem to be somewhere in the middle and pin 20 goes nowhere near going into the plastic hole
So good luck getting all 20 pins into that board without damaging something.
Hi bread_board.
Everyone, including me, has had plenty to say about your problems How are you getting on.
It would be nice to know if you have done any actual measurements and what your results are. I can only look at the pictures and make what I think are accurate observations. You are the only one that can actually measure as you have the offending item in front of you.
Would be nice to know if I am correct or otherwise.
Hi, my apologies! I don’t check Core Electronics often. I think I’ll try Jane’s advice first, and if that doesn’t work then the board itself was less than 4$ AUD so not really a big deal lol.
Also I don’t have a measuring tool with me right now.
On the contacts: my desk board has had Picos in and out of it and still grips standard component legs fine. A snug fit isn’t the same as a damaged one.
As for stocking both, it’s horses for courses. The ZY-60 is our most popular breadboard because most projects don’t need a premium one, and anyone who does is pointed to the professional boards right at the top of its description. Glad we agree on those for anyone who wants the tighter fit.
HiBlayden
Regarding the ZY60
Please do us all a favour and compare the photo bread_board posted and the photo of a ZY 60 on your web page. Note the position of the printed numbers 1 to 30. bread_boards pic shows the numbers over running the actual holes like the total length of the print is longer than the actual holes which helps me to say the hole pitch is 2.5mm and not 2.54mm. Now the print on your product page shows the printed numbers align with the holes much better and if anything have a bit of an error the other way.
Seeing this I think it is quite possible that the board you are using is and boards in your stock are correct and bread_board has a dodgy one
Please do this comparison and if possible a measurement n your board and stock ones and reply as I am interested if my observations are correct or not. It seems that breadboard does not have any measurement capabilities at this time which to be honest I find unusual.
I don’t think I have much more to say but I think a lot and not all good.
Hi bread_board
Go for it if you don’t mind a bit of damage. I personally don’t agree with Jane or Blayden approach. If I had done something like that instead of checking by measurement when working full time I would have been shown the door.
My last bit of advice for what it is worth is to get the board Blayden linked professional-grade breadboards
It is about $6 more expensive but will save much hassle in the long term.
Due to the situation where you are unable to measure the pitch of the board I don’t think there is any more I can offer except do yourself a favour and read all the replies and soak up the information therein.
Let us know how you get on.
