I am building a Raspberry Pi-based geocache system using a UPS HAT. The device will be installed in a remote outdoor location and left unattended for long periods (potentially months at a time). It will only be activated when a user interacts with it via a physical button.
The system runs a game (Pygame-based application), and is designed to operate as a self-contained interactive kiosk.
Power Behaviour Requirements
I am trying to design a reliable power system and would like guidance on the following behaviour:
Automatic Power-On
- The system should automatically power on when external power is connected or restored (e.g. plugging in a power bank or battery pack).
User Activation
- Alternatively, the system may remain in a low-power or standby state and be activated via a physical button press.
Automatic Shutdown
- The Raspberry Pi should be able to safely shut down via software after a period of inactivity (e.g. 1 hour of no user interaction).
Power Cut / Low Power State
After shutdown, I would like the system to ideally:
Fully cut power to the Raspberry Pi, OR
Enter a very low-power state to minimise battery drain
Wake Behaviour
The system should then be able to power back on either:
When the user presses a button, or
When external power is re-applied
Thank you!
