Setting x values based on digital read?
Hey Guys and Gals,
Having some issues setting x values based on a digital read.
It starts with the X value being 0 but when i change the input pin which should change the X value it says at 0???
any suggestions would be great.
p.s Using an Arduino Nano V3.2
here is the code in text
int pressure = A0;
int ledsolenoid = 5;
int set1 = 8 ;
int set2 = 9 ;
int set3 = 10 ;
int set4 = 11 ;
int x;
void setup() {
  pinMode(pressure, INPUT);
  pinMode(set1, INPUT);
  pinMode(set2, INPUT);
  pinMode(set3, INPUT);
  pinMode(set4, INPUT);
  pinMode(ledsolenoid, OUTPUT);
  Serial.begin(9600);
void loop() {
  Serial.println(x);
  delay(500);
  Serial.println(analogRead(pressure));
  delay(500);
  if (digitalRead(8)== HIGH){
 x = 200;}
if (digitalRead(set2)== HIGH){
 x = 300;}
if (digitalRead(set3)== HIGH){
 x = 400;}
if (digitalRead(set4)== HIGH){
 x = 100;}
else {
 x = 0;}
  if (analogRead(pressure) >= x){
    digitalWrite(ledsolenoid, HIGH);
    delay(100);
    digitalWrite(ledsolenoid, LOW);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
  else {
Hey Hunter,
I know this seems like a simple solution, but have you tried switching the definition of int x; to int x = 0;
this is only important for the first iteration of the loop as when the function Serial.println calls x as an argument, it would have no assigned value (at least initially) otherwise the code looks good!
int pressure = A0;
int set1 = 8 ;
int set2 = 9 ;
int set3 = 10 ;
int set4 = 11 ;
int x = 0;
void setup() {
  Serial.begin(9600);
void loop() {
  Serial.println(x);
  delay(500);
  delay(500);
 x = 200;}
 x = 300;}
 x = 400;}
 x = 100;}
else {
 x = 0;}
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
  else {
Bryce
Core Electronics | Support
hey mate,
just tried that, but it doesn’t seem to change what the x value is??? it stays at 0 and when i change the pin it doesn’t change the x value
Hi Hunter,
Welcome to the forum :slight_smile:
It can often help to turn on verbose output from the compiler in the Arduino IDE (File -> Preferences)
Doing so and trying to compile I get the following error message:
C:\Users\Support\AppData\Local\Temp\arduino_modified_sketch_754425\BareMinimum.ino: In function 'void loop()':
BareMinimum:72:1: error: expected '}' at end of input
exit status 1
BareMinimum:72:1 means the error is in the file BareMinimum, line 72, character 1. (My file was named BareMinimum, this’ll be whatever yours is named). Noting this is the end of the file, and it’s looking for a close brace, there’s a good chance you haven’t closed off all your braces, or you’ve got an extra open one somewhere.
Regards,
Oliver
Support | Core Electronics
I have this preference on and am getting an good compilation.
Am i missing something that wipes the memory of what the variable is equal to??
thanks
Hi Hunter,
Your issue is here:
 delay(500);
 x = 200;}
 x = 300;}
 x = 400;}
 x = 100;}
else {
 x = 0;}
You have an additional { after delay(500);.
And after your series of if statements, you’ll only ever get x=100 (if pin11 is high), and x=0 in all other cases.
You should re-write this to:
  delay(500);
 x = 200;}
else if (digitalRead(set2)== HIGH){
 x = 300;}
else if (digitalRead(set3)== HIGH){
 x = 400;}
else if (digitalRead(set4)== HIGH){
 x = 100;}
else {
 x = 0;}
Regards,
Oliver
sweet
I had to change to your edited code ( thankyou for that ) and am now getting a reading of 200 and 0 depending on the location of the pin.
I have a number of pins connected to my rotary switch all with a empty slot separating them, whenever i am on an empty pin the computer sets x to 0 but whenever on on a connected slot connected to the arduino im getting 200
this is the updated code
int pressure = A0;
int x = 0;
void setup() {
  pinMode(8, INPUT);
  pinMode(9, INPUT);
  pinMode(10, INPUT);
  pinMode(11, INPUT);
  Serial.begin(9600);
void loop() {
  Serial.println(x);
  delay(500);
  delay(500);
 x = 200;}
else if (digitalRead(9)== HIGH){
 x = 300;}
else if (digitalRead(10)== HIGH){
 x = 400;}
else if (digitalRead(11)== HIGH){
 x = 100;}
else {
 x = 0;}
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
  else {digitalWrite(ledsolenoid, LOW);}
Hey Hunter,
Could you please send us through a picture of your wiring, it’s important to note that in the logic which you’re currently using that the value will be set to the first HIGH reading that the microcontroller reads.
Bryce
Oh mate I forgot to close the forum it’s mint I got it to work
Thanks for the help
Hi Hunter,
Excellent, glad to hear it!
Regards,
Oliver
