SparkFun ESP32 Thing Environment Sensor Shield (DEV-14153)
This is a placeholder topic for “SparkFun ESP32 Thing Environment Sensor Shield” comments.
The SparkFun ESP32 Thing Environment Sensor Shield provides sensors and hookups for monitoring environmental conditions. While incorporating three sensors capable … read more
I’ve successfully hooked up this shield, however the temperature it reports is routinely 5 to 6 C above the actual temperature. This ieven before I put it into an enclosure. I’ve seen some posts on the Sparkfun site reporting similar issues but not resolution on how to fix it. Any suggestions?
Hi Allan,
Have you tested it at different temperatures? If it is a linear difference (always exactly 5.5 degrees above actual) then it should be pretty easy to correct in the code.
Let me know what you find!
