My friends at Core promptly sent me the SPI Driver which I score at 10/10.
The only problem I have is that Win11 generates a file permissions error when running spicl.exe in command line format. It sees the .exe just fine and spicl tries to run but Win generates a CreatFile Error 5…which is permissions related.
Anyone seen this before? (I should have learned Linux when I had the chance )
So, I bit the bullet and just moved my Dev PC from Win11 to Ubuntu 20. This saved me from stuffing around with Windows and I had to move over to a version of Linux at some point anyway.
Anyhow, I downloaded the Linux version of SPIDriver but Ubuntu can’t run it because it can’t see it in the download folder. The actual filename is spigui-linux64 but I can’t see the file extension (.bin, etc)
Then once it is executable if it is supposed to be an executable binary you can run the file by running ./filename, where did you download it to, and can you please run ls -a on that folder from a terminal so we can see what file types we’re dealing with?
Thanks Bryce, I went into the Properties on the file and ticked ‘Make Executable’ then ran it as you described. It’s located, as you can see, in the Downloads folder.
OK, so I got the spicl utility up and going pretty good which is the main thing. I can send multiple bytes to the device which is exactly what I’ll be doing testing the crazy wicking bed project.
The compile on the GUI still fails but I’m thinking there’s a bunch of extra files needed but I’m not fussed with it.
Gerard
