# Temperature sensors
**URL:** <https://forum.core-electronics.com.au/t/temperature-sensors/24525>\
**Category:** Uncategorized\
**Created:** [29 October 2026 06:04 UTC](https://forum.core-electronics.com.au/t/temperature-sensors/24525 "2026-10-29T06:04:53Z")\
**Showing post:** 4
**Author:** ![Donald23173](https://yyz2.discourse-cdn.com/flex028/user_avatar/forum.core-electronics.com.au/donald23173/32/12687_2.png) [@Donald23173](https://forum.core-electronics.com.au/u/Donald23173)\
**Post date:** [30 October 2026 06:30 UTC](https://forum.core-electronics.com.au/t/temperature-sensors/24525/4 "2026-10-30T06:30:37Z")
Hi Peter, interesting use case … and not difficult. Actually, deciding _how_ to do it is probably the hardest part, because I can see several approaches each with pro’s and con’s … and various options.
For example … there are a large number of off-the-shelf battery operated temperature sensors which link by wi-fi or bluetooth to your mobile phone (eg Bunnings sell the TP-Link Tapo T310 Smart Temperature And Humidity Monitor for $29) … but most of these use internet and cloud servers (which you have no control over).
Here on Core Electronics forum you will find people more likely to encourage building your own electronic solution. Again, there are plenty of Temperature sensors to choose from (some also sensing CO2 air quality which might be important if you are pumping in fresh air), and the extra effort to solder the components (or modules in my case) is offset against having full control over your system.
So saying, it would be helpful to know a little more about your situation…
Do you have an existing system are you going to link this in to ? What are you thinking of doing with the sensor readings ? Just to display them somewhere, or create automations based on them ?
> [@Peter335919](#):
> to read outside air temp., inside air temp, outside ground temp and incoming fresh air temp
Are the 2 outdoor sensors quite close; and are the 2 inside sensors also quite close ? Is power available at each location ? You mentioned a 7 meter wire to connect them …
Like Jane, I am also a fan of ESP32 microcontrollers - though in my case I prefer to use [ESPHome](https://esphome.io/) and [Home Assistant](https://www.home-assistant.io/) to control them rather than writing custom programs.
Personally I feel more comfortable with digital electronics, so I tend to use devices with i2c interfaces - but i2c is definitely designed for short distances. Then I came across [Adafruit LTC4311 I2C Extender / Active Terminator](https://core-electronics.com.au/adafruit-ltc4311-i2c-extender-active-terminator-stemma-qt-qwiic.html), and the [SparkFun QwiicBus - EndPoint](https://core-electronics.com.au/sparkfun-qwiicbus-endpoint.html) which extends i2c over Ethernet cable !
_[View the full topic](https://forum.core-electronics.com.au/t/temperature-sensors/24525)._
