We currently have a radio link network that connects 15 serial TTL pumps back to a central controller. We are currently using a radio link to connect the sites to the controllers in a Hub/Spoke manner. All data from the central controller is sent to each endpoint, however data from each endpoint is only sent to the central controller (not to all endpoints).
Each pump is allocated a “channel” which is sent as part of the header of each batch of data in order for the pumps to filter out data packets not meant for them.
What we are looking for is a solution that enables us to have a central unit that will connect to our central controller over serial TTL, as well as endpoint units that will connect to our pumps.
Do you currently sell equipment that will allow us to do this?
