What's the difference?
What is the difference between MAX3232ESE and MAX3232CSE? Is it interchangeable?
Hi Rose
You could compare data sheets but probably not a lot of difference if any at all except the suffix letters.
As the document in the link says, ESD Protected.
I think the β€˜E’ version has high Electro Static Discharge protection whereas the β€˜C’ version has normal protection. Electrically they should be the same. Physically too because of the β€˜SE’ in the part number.
Hey there @Rose278320!
As mentioned by @James46717, these two chips seemingly only differ regarding ESD. The datasheet shows a difference in temperature range, likely a result of the extra protection.
Though some minor research seems to reveal that neither chip is produced anymore and have both been superseded by the MAX3232ESE+ and MAX3232CSE+, as Mouser lists the original CSE as obsolete, and doesn’t list the original ESE at all.
Strangely, neither of the β€œ+” variants of the chips are ESD-protected.
Hope this helps.
The + versions probably include ESD protection, technology has vastly improved from what is was when I was learning electronics, many decades ago. Also, RS232 is a very old transmission standard and has been surpassed by other better standards today.
