A01NYUB ultrasonic sensor to Thingspeak UNO WiFi Rev 2
Hello,
I have an A01NYUB ultrasonic sensor up and running using the DF Robot sample code. the sensor works great.
I have then copied and pasted the identical sensor code into a Thingspeak sample code (write multiple fields), and the sensor now will only return 0 as a value.
Both the original sample codes work fine and now that I have combined them I have a problem - but can’t seem to work it out.
Any ideas to point me in the right direction would be great. Thank you
Hey Nicholas,
We’re sorry to hear you’re running into some issues with that one. I’m not super familiar with Thingspeak, so someone who has a bit more knowledge in that field may be able to help out a bit, but I’ll do my best to help!
Just to confirm, what microcontroller board were you using?
Hello!
I am using the Arduino Wifi Rev 2
Hey Nicholas,
Thanks for confirming!
Have you been able to run other programs/code on the WiFi Rev 2 while using Thingspeak?
If you have been able to get any sort of sensor input reading working (digital or analog), let us know and if possible, shoot through some code of that as well as the code you’re attempting to run for the A01NYUB.
Yes, this code uploads to Thingspeak no problem:
WriteMultipleFields
Description: Writes values to fields 1,2,3,4 and status in a single ThingSpeak update every 20 seconds.
Hardware: Arduino Uno WiFi Rev2
!!! IMPORTANT - Modify the secrets.h file for this project with your network connection and ThingSpeak channel details. !!!
Note:
  • Requires WiFiNINA library.
  • This example is written for a network using WPA encryption. For WEP or WPA, change the WiFi.begin() call accordingly.
ThingSpeak ( https://www.thingspeak.com ) is an analytic IoT platform service that allows you to aggregate, visualize, and
analyze live data streams in the cloud. Visit https://www.thingspeak.com to sign up for a free account and create a channel.
Documentation for the ThingSpeak Communication Library for Arduino is in the README.md folder where the library was installed.
See https://www.mathworks.com/help/thingspeak/index.html for the full ThingSpeak documentation.
For licensing information, see the accompanying license file.
Copyright 2018, The MathWorks, Inc.
#include “ThingSpeak.h”
#include <WiFiNINA.h>
#include “secrets.h”
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
WiFiClient client;
unsigned long myChannelNumber = SECRET_CH_ID;
const char * myWriteAPIKey = SECRET_WRITE_APIKEY;
// Initialize our values
int number1 = 0;
int number2 = random(0,100);
int number3 = random(0,100);
int number4 = random(0,100);
String myStatus = “”;
void setup() {
Serial.begin(115200); // Initialize serial
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println(“Communication with WiFi module failed!”);
// don’t continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv != “1.3.0”) {
Serial.println(“Please upgrade the firmware”);
ThingSpeak.begin(client); //Initialize ThingSpeak
void loop() {
// Connect or reconnect to WiFi
if(WiFi.status() != WL_CONNECTED){
Serial.print(“Attempting to connect to SSID: “);
Serial.println(SECRET_SSID);
while(WiFi.status() != WL_CONNECTED){
WiFi.begin(ssid, pass); // Connect to WPA/WPA2 network. Change this line if using open or WEP network
Serial.print(”.”);
delay(5000);
Serial.println("\nConnected.");
// set the fields with the values
ThingSpeak.setField(4, number1);
ThingSpeak.setField(5, number2);
ThingSpeak.setField(6, number3);
ThingSpeak.setField(7, number4);
// figure out the status message
//if(number1 > number2){
myStatus = String(“field1 is greater than field2”);
// else if(number1 < number2){
//myStatus = String(“field1 is less than field2”);
// else{
// myStatus = String(“field1 equals field2”);
// set the status
//ThingSpeak.setStatus(myStatus);
// write to the ThingSpeak channel
int x = ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
if(x == 200){
Serial.println(“Channel update successful.”);
else{
Serial.println("Problem updating channel. HTTP error code " + String(x));
// change the values
number1++;
if(number1 > 99){
number1 = 0;
delay(20000); // Wait 20 seconds to update the channel again
An this is the code where the sensor is returning 0:
#include <SoftwareSerial.h>
WiFiClient client;
// NEW defines variables
SoftwareSerial mySerial(11,10); // RX, TX
unsigned char data[4]={};
int distance;
int volume;
void setup() {
mySerial.begin(9600); // RX TX
// don’t continue
while (true);
void loop() {
// RX TX A01NYUB ultrasonic sensor
do{
for(int i=0;i<4;i++)
data[i]=mySerial.read();
}while(mySerial.read()==0xff);
mySerial.flush();
if(data[0]==0xff)
int sum;
sum=(data[0]+data[1]+data[2])&0x00FF;
if(sum==data[3])
distance=(data[1]<<8)+data[2];
volume = -0.067*distance +125; //calculate the % full
Serial.print(”.”);
delay(5000);
ThingSpeak.setField(4, distance);
ThingSpeak.setField(5, volume);
if(x == 200){
Serial.println(distance);
Serial.println(volume);
else{
