This is a placeholder topic for “Acetal MOD 0.8 Gear Rack (118 Tooth, 41 Hole)” comments.
This MOD 0.8 pitch, 118 tooth gear rack is the same one used in the goBILDA® Servo-Driven Gear Rack Kits (
How much weight can this hold/lift?
Hi Anthony, welcome to the forum!
That gear rack is designed for use in a larger kit, which does have thrust limits listed, so it’d be good for at least that, however you’d probably need to run a sim on the STEP file or see if there are rules of thumb floating around the internet for anything beyond that:
