Hi Ton,
Great to hear you got it running in the end, thanks for reporting back and letting us know.
@Jeff105671 Could you please clarify what lines were missing between steps 3 and 4? Then I can get the extra instructions added to the project writeup.
If my examination of the Tripler PCB layout is correct, then GND and Vcc are connected through, but Tx/Rx on the GPS needs to be wired to Rx/Tx on the Feather and SCL and SDA on the display needs to be wired through to SCL and SDA on the Feather. So some soldering is required.
Hi Jeff,
I agree with your interpretation of the Tripler layout, I’ve edited the instructions in that project to contain that extra step. It should push live to the website over the next 24 hours, otherwise you can read the updated project here.
