What Arduino hardware is required to work with arducontroller to enable Arduino to be controlled from Android phone?
The site says Connections: Ethernet/Wifi or Bluetooth"
But standard Arduino does not have Wifi etc.
I have a Uno with WiFi from Jaycar.
What code do I use in the ESP chip to allow phone to connect to Arduino?
Can you give us a link to the exact Arduino Uno version you have? From your message it sounds like it has an ESP co-processor which handles the WiFi. There are also ESP boards that are stand-alone with WiFi built in that can be programmed using the Arduino IDE, but they aren’t conventional Arduinos, so I want to make sure we’re on the same page about what hardware you’ve got.
Can you please include a link to what resources you were reading so we can get caught up quickly with where you are up to?
Everything went ok with this project EXCEPT I could not insert the tool that enables Arduino IDE to “download sketch data”. This option does not appear on the IDE. I have re-installed IDE 8-10 times following the instructions, but NADA. Hence I can’t download the web server files to the board
How would ArduController control IO of Uno, given the board has 2 chips: Uno and ESP8266? Can this combo work? What code is required for ESP8266 to communicate with the Uno chip?
FINALLY
If the above can’t work, maybe I could try RaspController with RPi, but RPi an expensive option (the kid I’m trying to help is a HSC student doing Design Tech)
I would appreciate any advice on the above, in the order above
I suggest you stop replying via email, your signature is getting appended to your post, and will be on the public internet forever for bots to pick up your phone number.
Arduino 2.0 is an entirely different system to 1.X, it’s based on VSCode as opposed to the old Java based Arduino IDE. You can’t ignore that warning, but you can download an the Legacy IDE here:
