Arduino Uno R3 LIS3DH accelerometer connection problems
Hello, I am trying to get my picodev LIS3DH accelerometer (PiicoDev 3-Axis Accelerometer LIS3DH | Buy in Australia | CE08705 | Core Electronics) working with my Arduino Uno r3 and have run into a few issues regarding connecting to the sensor. I soldered the sensor to header pins myself and found that the address is 0x19 (from the datasheet.)
Here is a diagram of what my circuit looks like:
Here is what my code looks like (I got it from the examples of the Adafruit_LIS3DH library):
// Basic demo for accelerometer readings from Adafruit LIS3DH
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
// Used for software SPI
// #define LIS3DH_CLK 13
// #define LIS3DH_MISO 12
// #define LIS3DH_MOSI 11
// Used for hardware & software SPI
// #define LIS3DH_CS 10
// software SPI
// Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
// hardware SPI
// Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS);
// Low Power 5Khz data rate needs faster SPI, and calling setPerformanceMode & setDataRate
// Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, 2000000);
// I2C
Adafruit_LIS3DH lis = Adafruit_LIS3DH();
void setup(void) {
  Serial.begin(115200);
  while (!Serial) delay(10);     // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("LIS3DH test!");
  if (!lis.begin(0x19)) {   // change this to 0x19 for alternative i2c address
    Serial.println("Couldn't start");
    while (1) yield();
  Serial.println("LIS3DH found!");
  // lis.setRange(LIS3DH_RANGE_4_G);   // 2, 4, 8 or 16 G!
  Serial.print("Range = ");
  Serial.print(2 << lis.getRange());
  Serial.println("G");
  // lis.setPerformanceMode(LIS3DH_MODE_LOW_POWER);
  Serial.print("Performance mode set to: ");
  switch (lis.getPerformanceMode()) {
    case LIS3DH_MODE_NORMAL: Serial.println("Normal 10bit"); break;
    case LIS3DH_MODE_LOW_POWER: Serial.println("Low Power 8bit"); break;
    case LIS3DH_MODE_HIGH_RESOLUTION: Serial.println("High Resolution 12bit"); break;
// lis.setDataRate(LIS3DH_DATARATE_50_HZ);
  Serial.print("Data rate set to: ");
  switch (lis.getDataRate()) {
    case LIS3DH_DATARATE_1_HZ: Serial.println("1 Hz"); break;
    case LIS3DH_DATARATE_10_HZ: Serial.println("10 Hz"); break;
    case LIS3DH_DATARATE_25_HZ: Serial.println("25 Hz"); break;
    case LIS3DH_DATARATE_50_HZ: Serial.println("50 Hz"); break;
    case LIS3DH_DATARATE_100_HZ: Serial.println("100 Hz"); break;
    case LIS3DH_DATARATE_200_HZ: Serial.println("200 Hz"); break;
    case LIS3DH_DATARATE_400_HZ: Serial.println("400 Hz"); break;
    case LIS3DH_DATARATE_POWERDOWN: Serial.println("Powered Down"); break;
    case LIS3DH_DATARATE_LOWPOWER_5KHZ: Serial.println("5 Khz Low Power"); break;
    case LIS3DH_DATARATE_LOWPOWER_1K6HZ: Serial.println("1.6 Khz Low Power"); break;
void loop() {
  lis.read();      // get X Y and Z data at once
  // Then print out the raw data
  Serial.print("X:  "); Serial.print(lis.x);
  Serial.print("  \tY:  "); Serial.print(lis.y);
  Serial.print("  \tZ:  "); Serial.print(lis.z);
  /* Or....get a new sensor event, normalized */
  sensors_event_t event;
  lis.getEvent(&event);
  /* Display the results (acceleration is measured in m/s^2) */
  Serial.print("\t\tX: "); Serial.print(event.acceleration.x);
  Serial.print(" \tY: "); Serial.print(event.acceleration.y);
  Serial.print(" \tZ: "); Serial.print(event.acceleration.z);
  Serial.println(" m/s^2 ");
  Serial.println();
  delay(200);
When I try to run the above code with the circuit, it results in this serial monitor response:
LIS3DHLIS3DH test!
Or sometimes when I run it, it prints:
LIS3DH testLIS3DH test!
This is not what you’d expect from the code, what is going on here?
Here is a picture of my soldering from the sensor to header pins:
Here is a picture of my soldering from the voltage level shifter to header pins:
Could you please help me to debug this issue and fix my code and accelerometer? Thank you very much for your time!
Hi Matthew
You have to connect the grounds of the level converter to the Arduino and LIS3DH. And 5V and 3.3V to the VHigh and VLow on the level converter. That is if the level converter is the type I think it probably is.
In other words you are missing 4 connections.
Upload an I2C scanner sketch to confirm if the LIS3DH at address 0x19 is detected.
Hi Bob,
Sorry for the misunderstanding, I forgot to add those connections to my drawing (they are in my circuit.) I have updated the diagram, thanks!
Hi Lia,
I’m using the “Adafruit testbed” library to scan my i2c and a similar issue to the previous one has come up. Here is the code that is found under the “examples” of the testbed library that I am using:
#include <Adafruit_TestBed.h>
extern Adafruit_TestBed TB;
#define DEFAULT_I2C_PORT &Wire
// Some boards have TWO I2C ports, how nifty. We should scan both
#if defined(ARDUINO_ARCH_RP2040) \
    || defined(ARDUINO_ADAFRUIT_QTPY_ESP32S2) \
    || defined(ARDUINO_ADAFRUIT_QTPY_ESP32S3_NOPSRAM) \
    || defined(ARDUINO_ADAFRUIT_QTPY_ESP32S3) \
    || defined(ARDUINO_ADAFRUIT_QTPY_ESP32_PICO) \
    || defined(ARDUINO_SAM_DUE) \
    || defined(ARDUINO_ARCH_RENESAS_UNO)
  #define SECONDARY_I2C_PORT &Wire1
#endif
void setup() {
  // Wait for Serial port to open
  while (!Serial) {
    delay(10);
  delay(500);
  Serial.println("Adafruit I2C Scanner");
#if defined(ARDUINO_ADAFRUIT_QTPY_ESP32S2) || \
    defined(ARDUINO_ADAFRUIT_QTPY_ESP32S3_NOPSRAM) || \
    defined(ARDUINO_ADAFRUIT_QTPY_ESP32S3) || \
  // ESP32 is kinda odd in that secondary ports must be manually
  // assigned their pins with setPins()!
  Wire1.setPins(SDA1, SCL1);
#endif
#if defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2)
  // turn on the I2C power by setting pin to opposite of 'rest state'
  pinMode(PIN_I2C_POWER, INPUT);
  delay(1);
  bool polarity = digitalRead(PIN_I2C_POWER);
  pinMode(PIN_I2C_POWER, OUTPUT);
  digitalWrite(PIN_I2C_POWER, !polarity);
#endif
#if defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2_TFT)
  pinMode(TFT_I2C_POWER, OUTPUT);
  digitalWrite(TFT_I2C_POWER, HIGH);
#endif
Here is the serial output:
Default port (Wire) I2C scan: Adafruit I2C Scanner
It seems that part of this issue might be to do with the serial outputs, I double checked the baud rates of the code and my serial monitor and they are matching. To try and debug this I tried running some code that just prints hello once in the serial monitor:
void setup() {
  Serial.print("hello");
void loop() {
  // put your main code here, to run repeatedly:
hellohello
It seems that the serial monitor is definitely part of this issue.
The Adafruit Library example is for an SPI interface, the Adafruit product can use SPI or I2C, the PiicoDev is only for I2C. From a quick examination of the .h file the interface is determined by how to initialise the driver.
This line should do it Adafruit_LIS3DH lis = Adafruit_LIS3DH(); I think.
The 3 types that can be setup are
Adafruit_CPlay_LIS3DH(TwoWire *Wi = &Wire);
Adafruit_CPlay_LIS3DH(int8_t cspin, SPIClass *theSPI = &SPI);
Adafruit_CPlay_LIS3DH(int8_t cspin, int8_t mosipin, int8_t misopin, int8_t sckpin
And it does look like something is amiss with the serial output.
I don’t have time to look into this further, but that is where I would start.
EDIT: The three types of instances I listed are from Adafruit Circuit Playground. I found 2 libraries on my PC; Adafruit_LIS3DH and Adafruit_CPlay_LIS3DH. They are very similar with some differences, I would use the Adafruit_LIS3DH first; if this is the case on your PC.
Hi Jim,
Thanks for the reply, I’ll look into that a bit more and see if I can get it working.
That sort of result in the monitor indicates that the code is restarting. This can be caused by power supply problems - how are you powering the UNO? It can also be caused by major program errors such as addressing non-existent memory. Hardware faults are another possibility. What IDE are you using and how is it configured for the UNO? Have you tested this setup with any other sketches and what was the result?
Hi Matthew
Naughty naughty. When you are asking for help with diagnosing things which has to be done remotely ACCURACY is paramount.
When I saw your drawing I thought well that is a pretty good reason why nothing works.
No harm done this time as it only took about 10 minutes to decide “well that won’t work” and compose an answer but sometimes it can take days to prise the correct information out of a person.
Accuracy and as much information as you can provide usually yields quick results.
Hi @matthew271007,
Good to see you have somewhere to start troubleshooting, let us know how it goes!
Regarding your original post, I love to see you including a diagram and code from the start, fantastic! As Bob said, it’s extremely important to make sure all the info you’re providing is correct, but at the end of the day, providing those things from the start helps us reach a quicker resolution!
For future, I recommend making block diagrams in a flow chart creator. My personal go-to is
It’s pretty standard, but allows for a lot more clarity in your diagrams. You could also use something like Fritzing to do this, but if the intent is a quick, simple, block diagram, I typically just use a flowchart designer.
Hello Jeff,
I’m powering my uno with a cable running from my usb port to the power/input area of my Arduino. I’m currently using IDE 3.3.3. I tried the SparkFunLIS3DH library and ran into some similar issues. I used the i2c example:
#include "SparkFunLIS3DH.h"
#include "Wire.h"
#include "SPI.h"
//Create two instances of the driver class
LIS3DH SensorOne( I2C_MODE, 0x19 );
LIS3DH SensorTwo( I2C_MODE, 0x18 );
void setup() {
  // put your setup code here, to run once:
  Serial.begin(9600);
  delay(1000); //relax...
  Serial.println("Processor came out of reset.\n");
  //Call .begin() to configure the IMUs
  if( SensorOne.begin() != 0 )
	  Serial.println("Problem starting the sensor at 0x19.");
  else
	  Serial.println("Sensor at 0x19 started.");
  if( SensorTwo.begin() != 0 )
	  Serial.println("Problem starting the sensor at 0x18.");
  else
	  Serial.println("Sensor at 0x18 started.");
Here was the output:
Thanks for your reply Zach! I’ll make sure to use the flowchart next time. Apologies for the left out info.
Hi Bob,
I apologise for my oversight and thank you for your help.
The most recent Arduino IDE is 2.3.3: is that the one you mean? If so it is unlikely to be the direct cause of the problems. It is possible that if you have not configured the board manager properly and the IDE does not detect the error then it might execute invalid code and cause the restart, so check that you have selected the correct board for your MCU.
The other possible cause of that type of restarting is that the watchdog timer is not getting reset regularly. However AFAIK it is not running by default, and I can’t see that any of the code you are using is would start it for you, so that is not likely to be the issue. If it was the watchdog timer then it would indicate that your code is hung up somewhere.
The most likely cause of the restarts is that the USB port you are using cannot supply enough current to power the UNO, the LIS3DH and the level converter. You will get a clue to this possibility if you run a simple sketch on the UNO with nothing else connected. If that works, then try the same sketch with the other bits connected and see what happens. The blink example is suitable, with the extra code in Setup to print a message to tell you whether it is restarting and re-running Setup, or just looping in the main loop like it should. If that doesn’t work then it’s possible that the port does not have enough power for the UNO on its own, although I would think that unlikely, unless you are using a very poor cable. In that case you should source a separate 9V supply and provide that to the barrel jack on the UNO. You can have both the USB cable and the separate supply connected at the same time.
Hello Jeff,
I removed the logic level shifter and the LIS3DH from my circuit and ran the code. This time it worked (of course it printed “Couldnt start” because there is no circuit attached.) I’ll try adding a 9V power supply to help fix this issue and let you know how it goes. Just so I know what to look for next time when debugging could you please tell me why a lack of power caused these issues? Thank you very much!!!
Hi Jeff, I added a 9V battery to my Arduino (the battery definitely works as when I removed the usb my arduino was still powered.) Unfortunately, it still returns the: LIS3DH tesLIS3DH test!
To be clear - it printed “Couldn’t start” after printing “LIS3DH test!” without the stuttering? If so, that test has eliminated any configuration problem with the board manager and any possibility of the code doing something illegal and causing the reboot.
When the MCU detects that the supply voltage is too low it turns off. When it turns off it reduces the load on the power supply, so the voltage recovers. That causes the MCU to restart. Sometimes that cycle goes on forever, sometimes it stops after several cycles.
The 9V supply should have helped if the UNO was the problem, but the level shifter and LIS3DH are hanging off the 3V3 regulator, and the increased supply to that regulator will have only a small effect on the capability of that supply. So my guess is that either the level shifter or the LIS3DH is loading the 3V3 supply very heavily.
Firstly, do a very thorough examination of the pins and soldering of the level shifter and LIS3DH. Use a good magnifying glass and a bright light. Scrape between the pins with a blade or needle in case some flux is hiding a solder whisker.
Then try with only the UNO and the level shifter 5V+/- connected, then add the 5V connections between the level shifter and the UNO, then add the 3v3+/- from the UNO to the level shifter, then add the 3V3+/- the LIS3DH (without the data connections). That covers all other possible combinations, and should reveal where the problem is occurring.
Hello Jeff, I’ll trial out the debugging steps that you suggested and come back with any results. Thank you very much for all the time you’ve put in to helping me, I really appreciate it!
Hi Jeff
If that 9V battery Matthew used is of the little block type do you think it would have enough grunt to drive all that load. I don’t know off the top of my head just what the capability of one of those is and I just don’t have the time this minute to research it but I personally would have some doubts.
Hi Jeff,
I couldn’t find any solder whiskers in my soldering.
Here are my results:
With just LV side of logic level (the data pins included)
With just HV side of logic level (the data pins included):
LIS3DH test! start
LIS3DH test!
Couldn't start
With Both of them (the data pins included):
LIS3DH test start
LIS3DH test!
Couldn't start
Cheers!
