I am needing help with code for Arduino Uno .What I need it to do is read 5 different RFIDs that have to be placed in the correct place. I have 5 Tiki Statues that are different color and I need the correct color to be placed in the correct spot to open a magnetic look. It doesn’t matter which color is place first just the correct place. In have code to do 3 like this but cant get it to work with 5. I am new to this so any help is appreciated. Here is what I have
- Typical pin layout used:
MFRC522 Arduino Arduino Arduino Arduino Arduino -
Reader/PCD Uno/101 Mega Nano v3 Leonardo/Micro Pro Micro - Signal Pin Pin Pin Pin Pin Pin
- RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
- SPI SS 1 SDA(SS) ** custom, take a unused pin, only HIGH/LOW required **
- SPI SS 2 SDA(SS) ** custom, take a unused pin, only HIGH/LOW required **
- SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
- SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
- SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_1_PIN 10 // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 2
#define SS_2_PIN 8 // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
#define SS_3_PIN 7 // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
#define NR_OF_READERS 3
byte ssPins[] = {SS_1_PIN, SS_2_PIN,SS_3_PIN};
MFRC522 mfrc522[NR_OF_READERS]; // Create MFRC522 instance.
String read_rfid;
String ValidCard_1 = “8cc1ad85”;
String ValidCard_2 = “5efc1f2b”;
String ValidCard_3 = “1196b85”;
boolean Card_1_ok = false;
boolean Card_2_ok = false;
boolean Card_3_ok = false;
int Read1 = 9;
int Read2 = 9;
boolean ValidCardOrder = true;
String Prevcard = “”;
int NoCardCnt = 0;
int DoorLockPin = 4;
int DoorOpenSec = 2;
- Initialize.
void setup() {
pinMode(DoorLockPin,OUTPUT);
digitalWrite(DoorLockPin,HIGH);
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
Serial.print(F("Reader “));
Serial.print(reader);
Serial.print(F(”: "));
mfrc522[reader].PCD_DumpVersionToSerial();
- Main loop.
void loop() {
if (NoCardCnt > 150){
Card_1_ok = false;
Card_2_ok = false;
Card_3_ok = false;
NoCardCnt = 0;
Prevcard = “”;
Read1 = 9;
Read2 = 9;
// Look for new cards
//Serial.println("Reading readers" + String(ValidCardOrder) + "-----" + String(Card_1_ok) + "--" + String(Card_2_ok) + "--" + String(Card_3_ok));
if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
Serial.print(F("Reader "));
// Show some details of the PICC (that is: the tag/card)
dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
Serial.println(read_rfid);
ValidateCard(reader);
// Halt PICC
mfrc522[reader].PICC_HaltA();
// Stop encryption on PCD
mfrc522[reader].PCD_StopCrypto1();
else{
NoCardCnt = NoCardCnt + 1;
delay(50);
//Serial.println("No card on sensor cnt" + String(NoCardCnt));
void dump_byte_array(byte *buffer, byte bufferSize) {
read_rfid = “”;
for (byte i = 0; i < bufferSize; i++) {
read_rfid = read_rfid + String(buffer[i], HEX);
void ValidateCard(int reader) {
if (reader == Read1) {
Serial.println(“Reader 1 already reads”);
goto GoNext;}
if (reader == Read2) {
Serial.println(“Reader 2 already reads”);
goto GoNext;}
int x;
Prevcard = read_rfid;
if (Card_1_ok == false && Card_2_ok == false && Card_3_ok == false){
if (ValidCard_1 == read_rfid){
Read1 = reader;
Card_1_ok = true;
NoCardCnt = 0;
goto GoNext;
else{
ValidCardOrder = false;
goto GoNext;
if (Card_1_ok == true && Card_2_ok == false && Card_3_ok == false){
if (ValidCard_2 == read_rfid){
Read2 = reader;
Card_2_ok = true;
NoCardCnt = 0;
goto GoNext;
else{
goto GoNext;
if (Card_1_ok == true && Card_2_ok == true && Card_3_ok == false){
if (ValidCard_3 == read_rfid){
Card_3_ok = true;
if (ValidCardOrder) {
open_lock();
else{
GoNext:
x = 0;
void open_lock(){
//Serial.println("****************************************** Door opened");
digitalWrite(DoorLockPin,LOW);
delay(DoorOpenSec*1000);
Card_1_ok = false;
Card_2_ok = false;
Card_3_ok = false;
NoCardCnt = 0;
Prevcard = “”;
