Hi John
I find if there are a few messages on the Email bit it is sometimes confusing getting the chronological order right so I always use the forum to answer. Seems easier to me anyway.
I can see that now and I can see what you have done. That is what I asked, to advise exactly what IC has been used.
You originally said you used the BOB09816. At no time have you advised you only used the circuit and produced your own board. I got worried when I discovered the Sparkfun board had used a 5V IC and I had advised you to use 12V. When you previously said you had the higher voltage IC I thought Sparkfun had made an error. Then yesterday when I looked closer at your sketch when I discovered I had guessed the wrong MP3 trigger board I saw the OP amp board was different too. I must have spent 2 or 3 hours trolling the web looking for a board that looked like the pic. Then I cropped it and blew it up it started to look a bit home made. At this stage I couldn’t read any resistor values as the image was too pixelated. Then you come up with the latest little gem confirming the board is indeed home made using the higher voltage IC.
The point I am making here is that it would have been a great help if this had been made known right from the word go. Firstly you still have not confirmed the part no for the MP3 trigger board. I guessed the wrong one and did not realise until I saw picture of your set up. Secondly you could have saved me a lot of worry and searching if you had said up front you had made a larger board and used a different IC for the OP amp breakout. I knew you wanted a better volume control but did not know you had built a complete board. While we are at it have you got any more little bits of information you think may be useful.
You need to remember I am trying to help remotely and am not looking over your shoulder to see what you have done. When you are describing things accuracy is paramount. Although I am retired I don’t have all day to sit in front of a computer guessing and hoping to be nearly right.
Cleared up a couple of issues, yes.
