I have reason to connect a Microchip MCP4821 DAC to my Adafruit HUZZAH32. However, it is not obvious to me where i should connect the CS, SCK and SDI pins of the DAC to the ESP32 board.
Can anybody advise the correct connections and possible provide sample Arduino source if available.
https://www.microchip.com/wwwproducts/en/MCP4821#additional-features
PS. I’m aware that the ESP32 has 2 DAC’s built in. However, i’m wanting to implement an ADC calibration process from a known and accurate source.
On the Huzzah,
CS - chip select, any available digital pin
SCK - clock, pin is marked SCK
MO - (MOSI) master out slave in, to SDI on the MCP.
The SPI pins are up near the antenna on the Huzzah.
Thanks! I see the MO and MI pins now.
We have set up our first test and it will not work as yet. We are getting no output from the MCP4821. We have carefully connected as follows:
MCP4821 = HUZZAH32
Vdd = 5Vdc
CS = A8 (pin 15 on HUZZAH32, is operating correctly)
SCK = SCK
SDI = MO
Vss = GND
SHDN = NC
LDAC = GND
Are we using the correct SPI library?
Is the SPI being initialized properly?
We do not have an oscilloscope so we cannot look at SCK or MO.
Does SCK have to be configured>
Is there anything obvious in the code below?
#include <SPI.h>
void setup() {
pinMode(A8, OUTPUT);
digitalWrite(A8, HIGH);
SPI.begin();
void loop() {
delay(1000);
digitalWrite(A8,LOW);
SPI.transfer(0x3800); //0011100000000000 should output 1.024V (2.048ref, Gain=1,Active)
digitalWrite(A8,HIGH);
Thanks heaps for any assistance.
Regards, Gerard Hook
