I’d really like to be able to turn it on and off, I tried connecting it to a GPIO as it’s also 3.3V, but with the load of the fan it drops to 2.2V and it doesn’t work. I’m also a little worried it would be a bit bad for the pi.
I also thought about putting the pi in deep sleep, but that leaves 3v3 high, and that’s probably a good thing for most uses.
Any suggestions on how to do it? Will I just have to live with it constantly on?
Hi Doug
Good if you want the thing to be on at all times. The Mosfet will stay on even if the 3V is removed. Pretty much forever unless the internal gate capacitor is discharged to source somehow.
So no, I don’t think this circuit as drawn would be successful.
Hi Liam & Doug
That extra resistor IS NOT required with that module. I believe the Pico I/O should source and sink. A high will turn the Mosfet ON and a low turn it OFF. The module has a 1kΩ resistor in series with the gate to limit I/O current to a safe value and a 10kΩ resistor from gate to source to make sure the gate capacitor is discharged when power is removed. It is not a “pull down” in the true sense where it would be necessary if the driving I/O did not sink.
One last question:
I’d like to shorten the cables a bit, is there an appropriate connector/crimping tool to make the ends plug into the header pins? I checked my local Jaycar and Altronics and they sayd they had nothing.
Ideally, something that’d let me do individuals, pairs (like jst), or 3 or 4
