How do I wire this up as the datasheet doesn’t mention the pin out (relative to the package) & there is no implied ground or power pins.
I’m planning on using an Arduino & 74HC595 shift register to set the segments & only require the ability to set all the segments to the same colour. I need to be able to set the RGB colour value dynamically. It woud be helpfull if you could point me at any projects using this product.
