i tried it too but instead it save’s a log file then print on terminal the name it detect including the date and time.
add these line to the top.
from datetime import datetime
import logging as log
log.basicConfig(filename='FILNAME.log',level=log.INFO)
#try to find these block of code and paste this
if True in matches:
# find the indexes of all matched faces then initialize a
# dictionary to count the total number of times each face
# was matched
matchedIdxs = [i for (i, b) in enumerate(matches) if b]
counts = {}
# loop over the matched indexes and maintain a count for
# each recognized face face
for i in matchedIdxs:
name = data["names"][i]
counts[name] = counts.get(name, 0) + 1
# determine the recognized face with the largest number
# of votes (note: in the event of an unlikely tie Python
# will select first entry in the dictionary)
name = max(counts, key=counts.get)
#print ("*********************************")
#log.info('*********************************')
print(counts)
log.info(counts)
log.info('Recognize Current Time')
print(datetime.utcnow().strftime('%Y-%m-%d %H:%M:%S.%f')[:-3])
log.info(datetime.utcnow().strftime('%Y-%m-%d %H:%M:%S.%f')[:-3])
#If someone in your dataset is identified, print their name on the
