I’m testing FireBeetle ESP32e with 18650 battery and it runs quite well without major issues so far. I’ve connected several sensors to the fireBeetle and deep sleep at 30 second interval right after MQTT upload. Once all setup, I’m planning to run the unit at 10 minute interval.
Now the questions:
FireBeetle already has TP4056 on board. If I want to charge the 18650 battery from 6v solar panel, can I directly connect the panel +/- to the VIN/GND pad behind the usb C port? Or is there any other way to do it?
I notice the “Low-power Solder Jumper Pad” on the board. Can I cut this?
For another project, I’m looking for an ePaper display. Which one you recommend for FireBeetle?
The maximum voltage input for the TP4056 from the datasheet is 8V, so as long as the open circuit voltage of your panel doesn’t exceed this, then you’re golden.
According to DFRobot this means the RGB LED will only work when the device has an external 5V. I couldn’t find it on the schematic so I’ll have to take their word on that one.
Looks like DFRobot themselves make one for the ESP32, so I’d go with that:
Broadly speaking though, any display should work if you can find a library for your dev environment (Arduino, Micropython, plain C, whatever)
Thanks James
Can’t wait till weekend when I can test it under the sunlight
(by the time I get home from work it’s dark already)
I’ll post the result once I get something!
I finally completed the test setup so I’m going to put the whole thing in my backyard tomorrow and see what happens. Fingers crossed!
If everything goes alright, I’ll 3d print a nice enclosure and waterproof it.
One weird thing. I cut the “Low-power Solder Jumper Pad” and now the red light is on. That LED has never turned on so far either USB powered or battery. What a weird (or stupid) thing it is!
Unfortunately it’s a failure. The firebeetle works great over the night but once the sun rises, it can’t wake up from the deep sleep. I suspect the charging voltage is a little too high. The solar panel is rated 6v and I think it’s actually over 5v during a normal sunny day. Do you think it’s worth purchasing another 5v panel and give it a go again? I’m a little disappointed and kinda lost interest…
Sorry to hear it’s giving you trouble! Do you have a multimeter handy to check the open circuit voltage of the panel? Those sporadic data points are weird!
Hi Jerry
Don’t know a great deal about exactly what you are trying to do but I find it highly suspicious that all of the sensor results seem to pretty faithfully follow the battery voltage variations.
What is the actual battery voltage.
What do the numbers on the left Y axis represent.
At present the only numbers that actually mean anything are the right Y axis ; temperature. But even this follows the battery curve. Suspicious what!!!
James,
Just got back from work.
The panel produces over 7V when it faces a direct sunlight even in the morning and I think that’s what makes everything goes wrong.
Even with more than half covered by masking tape, it still could produce 7V!
(the panel is listed 6v on eBay)
It’s my fault I should have checked the output voltage first before throw everything under the sun.
(I’m busy doing my day job so it’s actually difficult)
I think I need to put some sort of regulator between the panel and fireBeetle.
Anyway, don’t get confused by the voltage readings. It’s not perfectly smooth but clearly shows the trend if you just ignore the failure between 8:00am to 11:00am yesterday.
Note the three top lines aren’t doing anything (soil moisture sensors attached to 3 analog pins). Mid red dots are temperature readings from bme280 and the bottom line is the analog reading from A2 pin where the fireBeetle’s built in voltage divider is connected. I don’t know much about the electronics but people says you can get approximate voltage values if you multiply the readings by 2.
Bob,
Actually I don’t know exactly what I’m doing… and that’s the problem haha!
Have a look at the Grafana screenshot I attached to James’ comment. It’s not perfect but rather makes sense to me in terms of battery level reduction and temperature etc over last 2 days. Don’t worry about the 3 soil moisture sensors on top. They aren’t doing anything.
I put the whole thing in my backyard on Saturday night (1/4/23) and everything went alright until sun hit the panel at around 8:00am 2/4/23. The panel produced too much voltage (or current) and I think fireBeetle shut down due to this. I brought everything back to my workshop and after that all the lines look pretty stabilsed.
FYI, My fireBeetle’s built in voltage divider schematics are as follows:
Hi Jerry
The temperature still spiked very sharply at just after 8AM which would be unusual unless you can explain it like the sensor suddenly getting into direct sunlight.
Even though you claim the others are doing nothing they still show a sharp increase at the same time.
This suggests to me that the marriage between power source and electronics is not all that it could be. In other words it is not right.
I would suggest you get your power supply and /or connections etc in good order before you go chasing fairies. One thing to remember, if your power source is not doing the right thing you can’t expect anything else to work properly. Believe me it won’t.
PS. Those numbers on the left Y axis still don’t seem to relate to what the battery value actually is. They are only displaying a relative level and only indicate that the voltage goes up by some arbitrary amount when the sun shines. Not by how much.
Was the problem that the solar panel generated 7V which was too much for the Firebeetle (DFR0654) ? Curious that Firebeetle spec says Input Voltage: 3.3V~5.5V, yet the TP4056 spec shows max 8.0V.
How did you resolve the situation ? A different solar panel, a buck or step-down voltage regulator, or something else ?
Hi Donald
That 7V could be the panel “open circuit” voltage. In the Pic with the meter it looks like the panel is not connected to anything. Even a small load might reduce this to 6V or so. As a comparison I think (could be wrong) a panel rated at 12V has an open circuit voltage of up to about 17V. So the 7V might be normal???
Donald, I ended up using DFRobot’s Solar Power Manager, which took care of all the power-related issues. It worked really well for over a year without any major problems. However, the soil moisture readings weren’t very reliable or particularly helpful for tracking plant growth.
If you’re curious, feel free to check out my YouTube channel. I just make things for fun and don’t have any background in electronics, so I might not be able to answer technical questions in detail.
Hi Jerry
Well done.
For someone with no electronics background (as you stated) this is a well put together project. What was that glue you splashed around. seems to work pretty well.
Your soldering looks pretty good for a self confessed “new to electronics” person or anybody else for that matter.
I just have one comment. Did I see “tinned” wires going into screw down or rising clamp terminal blocks. That is a bit of a no no. If rising clamp type or wire protectors with screw down blocks using straight wires or use bootlace ferrules are the go. Different size wire or stranded with solid ferrules are a must as tinned wire will come loose with a dodgy connection over time.
Sorry about being picky. I still find it difficult getting rid of my QA hat even after many years since full time work.
Concerning your sensor readings. I note you covered the sensor and immediate area with the unit itself. There is a distinct possibility that moisture would condense under this during the day and result in an artificial higher reading..
Thank you Jerry. I am also currently using that Power Manager board, but with an INA3221 to measure battery, solar and USB-in power. I just don’t understand why DFRobot couldn’t add 2 resistors to give a voltage divider on their “manager” board … but that’s a different issue
I was asking because I am thinking to swap to one of the ESP-S3 microcontroller boards with the battery connector (like your ESP32-E) and wondering if you had used a 5V step up/down regulator for the solar panel.
I also have bought several soil moisture sensors … but most discussions were not very complimentary, so I don’t expect them to last too long. My partner is into Orchids, which prefer moisture on their leaves and not much on their roots, so the soil moisture is more of a “because i can” than particularly useful.
I suspect the issue with the solar panel not powering the Firebeetle may have been caused by lack of current - not by high voltage. The regulator built into the 5V 1A solar panel I use supplies a constant 5V but at a ridiculously low current unless there is strong light direct on the panel.
I guess the Firebeetle’s circuitry saw 5V and switched totally to the USB/5V input - but there wasn’t enough current to power the processor.
The Solar Power Manager board is more sophisticated and keeps both the battery and Solar panel and USB input in play … topping from the battery as required for the load, and any excess of input not needed by the load flowing into (charging) the battery.
So, while dev boards like firebeetle look good on specs, to use in a remote location (i.e. without a main-powered USB power adaptor) they still need a Solar Power Manager … and that SPM removes the benefit of connecting the battery to the dev board
