Font size increase for OLED Display Module SSD1306
I developed a library that produces 3 lines of 8 characters, easy to read from a distance.
It simply uses line drawing to make the characters. The library draws upper case, numeric and a few special characters. I have used it successfully in a number of projects.
Include these files.
Modified PiicoDev Library. PiicoDev_SSD1306_Large.py
# Modified from git hub library used by SSD1306_Large Text routines ****
# Sends data to the Core Electronics PiicoDev OLED SSD1306 Display
# Ported by Peter Johnston at Core Electronics October 2021
# Original Repos:
# 2021-09-12:
# https://github.com/micropython/micropython/blob/master/drivers/display/ssd1306.py
# 2021-08-01:
# https://github.com/fizban99/microbit_ssd1306/blob/master/ssd1306_text.py
# 2021-07-15:
# https://github.com/adafruit/Adafruit_Python_SSD1306/blob/master/Adafruit_SSD1306/SSD1306.py
# 2021 OCT 14 - Initial release
# 2022 JAN 04 - Remove dependency on PIL module.  Improve compatibility with pbm files.
# 2022 FEB 26 - Removed MicroBit and Linux routines to make smaller file
_SET_CONTRAST = 0x81
_SET_ENTIRE_ON = 0xA4
_SET_NORM_INV = 0xA6
_SET_DISP = 0xAE
_SET_MEM_ADDR = 0x20
_SET_COL_ADDR = 0x21
_SET_PAGE_ADDR = 0x22
_SET_DISP_START_LINE = 0x40
_SET_SEG_REMAP = 0xA0
_SET_MUX_RATIO = 0xA8
_SET_IREF_SELECT = 0xAD
_SET_COM_OUT_DIR = 0xC0
_SET_DISP_OFFSET = 0xD3
_SET_COM_PIN_CFG = 0xDA
_SET_DISP_CLK_DIV = 0xD5
_SET_PRECHARGE = 0xD9
_SET_VCOM_DESEL = 0xDB
_SET_CHARGE_PUMP = 0x8D
WIDTH = 128
HEIGHT = 64
from PiicoDev_Unified import *
from math import cos,sin,radians
import framebuf
class PiicoDev_SSD1306(framebuf.FrameBuffer):
    def init_display(self):
        self.width = WIDTH
        self.height = HEIGHT
        self.pages = HEIGHT // 8
        self.buffer = bytearray(self.pages * WIDTH)
        for cmd in (
            _SET_DISP,  # display off
            # address setting
            _SET_MEM_ADDR,
            0x00,  # horizontal
            # resolution and layout
            _SET_DISP_START_LINE,  # start at line 0
            _SET_SEG_REMAP | 0x01,  # column addr 127 mapped to SEG0
            _SET_MUX_RATIO,
            HEIGHT - 1,
            _SET_COM_OUT_DIR | 0x08,  # scan from COM[N] to COM0
            _SET_DISP_OFFSET,
            0x00,
            _SET_COM_PIN_CFG,
            0x12,
            # timing and driving scheme
            _SET_DISP_CLK_DIV,
            0x80,
            _SET_PRECHARGE,
            0xF1,
            _SET_VCOM_DESEL,
            0x30,  # 0.83*Vcc
            # display
            _SET_CONTRAST,
            0xFF,# maximum
            _SET_ENTIRE_ON,  # output follows RAM contents
            _SET_NORM_INV,  # not inverted
            _SET_IREF_SELECT,
            0x30,  # enable internal IREF during display on
            # charge pump
            _SET_CHARGE_PUMP,
            0x14,
            _SET_DISP | 0x01,  # display on
        ):  # on
            self.write_cmd(cmd)
    def poweroff(self):
        self.write_cmd(_SET_DISP)
    def poweron(self):
        self.write_cmd(_SET_DISP | 0x01)
    def setContrast(self, contrast):
        self.write_cmd(_SET_CONTRAST)
        self.write_cmd(contrast)
    def invert(self, invert):
        self.write_cmd(_SET_NORM_INV | (invert & 1))
    def rotate(self, rotate):
        self.write_cmd(_SET_COM_OUT_DIR | ((rotate & 1) << 3))
        self.write_cmd(_SET_SEG_REMAP | (rotate & 1))
    def show(self):
        x0 = 0
        x1 = WIDTH - 1
        self.write_cmd(_SET_COL_ADDR)
        self.write_cmd(x0)
        self.write_cmd(x1)
        self.write_cmd(_SET_PAGE_ADDR)
        self.write_cmd(0)
        self.write_cmd(self.pages - 1)
        self.write_data(self.buffer)
    def write_cmd(self, cmd):
        try:
            self.i2c.writeto_mem(self.addr, int.from_bytes(b'\x80','big'), bytes([cmd]))
            self.comms_err = False
        except:
            print(i2c_err_str.format(self.addr))
            self.comms_err = True
    def write_data(self, buf):
        try:
            self.write_list[1] = buf
            self.i2c.writeto_mem(self.addr, int.from_bytes(self.write_list[0],'big'), self.write_list[1])
        except:
    def circ(self,x,y,r,t=1,c=1):
        for i in range(x-r,x+r+1):
            for j in range(y-r,y+r+1):
                if t==1:
                    if((i-x)**2 + (j-y)**2 < r**2):
                        self.pixel(i,j,1)
                else:
                    if((i-x)**2 + (j-y)**2 < r**2) and ((i-x)**2 + (j-y)**2 >= (r-r*t-1)**2):
                        self.pixel(i,j,c)
    def arc(self,x,y,r,stAng,enAng,t=0,c=1):
        for i in range(r*(1-t)-1,r):
            for ta in range(stAng,enAng,1):
                X = int(i*cos(radians(ta))+ x)
                Y = int(i*sin(radians(ta))+ y)
                self.pixel(X,Y,c)
    def load_pbm(self, filename, c):
        with open(filename, 'rb') as f:
            line = f.readline()
            if line.startswith(b'P4') is False:
                print('Not a valid pbm P4 file')
                return
            line = f.readline()
            while line.startswith(b'#') is True:
                line = f.readline()
            data_piicodev = bytearray(f.read())
        for byte in range(WIDTH // 8 * HEIGHT):
            for bit in range(8):
                if data_piicodev[byte] & 1 << bit != 0:
                    x_coordinate = ((8-bit) + (byte * 8)) % WIDTH
                    y_coordinate = byte * 8 // WIDTH
                    if x_coordinate < WIDTH and y_coordinate < HEIGHT:
                        self.pixel(x_coordinate, y_coordinate, c)
    class graph2D:
        def __init__(self, originX = 0, originY = HEIGHT-1, width = WIDTH, height = HEIGHT, minValue=0, maxValue=255, c = 1, bars = False):
            self.minValue = minValue
            self.maxValue = maxValue
            self.originX = originX
            self.originY = originY
            self.width = width
            self.height = height
            self.c = c
            self.m = (1-height)/(maxValue-minValue)
            self.offset = originY-self.m*minValue
            self.bars = bars
            self.data = []
    def updateGraph2D(self, graph, value):
        graph.data.insert(0,value)
        if len(graph.data) > graph.width:
            graph.data.pop()
        x = graph.originX+graph.width-1
        m = graph.c
        for value in graph.data:
            y = round(graph.m*value + graph.offset)
            if graph.bars == True:
                for idx in range(y, graph.originY+1):
                    if x >= graph.originX and x < graph.originX+graph.width and idx <= graph.originY and idx > graph.originY-graph.height:
                        self.pixel(x,idx, m)
            else:
                if x >= graph.originX and x < graph.originX+graph.width and y <= graph.originY and y > graph.originY-graph.height:
                    self.pixel(x,y, m)
            x -= 1
class PiicoDev_SSD1306_MicroPython(PiicoDev_SSD1306):
    def __init__(self, bus=None, freq=None, sda=None, scl=None, addr=0x3C):
        self.i2c = create_unified_i2c(bus=bus, freq=freq, sda=sda, scl=scl)
        self.addr = addr
        self.temp = bytearray(2)
        self.write_list = [b'\x40', None]  # Co=0, D/C#=1
        self.init_display()
        super().__init__(self.buffer, WIDTH, HEIGHT, framebuf.MONO_VLSB)
        self.fill(0)
        self.show()
def create_PiicoDev_SSD1306(addr=0x3C,bus=None, freq=None, sda=None, scl=None):
    return PiicoDev_SSD1306_MicroPython(addr=addr, bus=bus, freq=freq, sda=sda, scl=scl)
Library to draw characters SSD1306_Large.py
# Large Font on SSD1306 OLED
# 3 lines of 8 characters each
from PiicoDev_SSD1306_Large import *
class SSD1306_8x3():
    def __init__(self):
        self.oled = create_PiicoDev_SSD1306()
    def display(self, text, p):
#        print(posArray[0][0])
        for i in range (len(text)):
            x=p[i][0]
            y=p[i][1]
            if text[i]=="A" or text[i]=="a":
                self.oled.line(x+1,y+15,x+5,y+1,1)
                self.oled.line(x+5,y+1,x+10,y+15,1)
                self.oled.line(x+3,y+11,x+8,y+11,1)
            elif text[i]=="B" or text[i]=="b":
                self.oled.line(x+1,y+15,x+1,y+1,1)
                self.oled.line(x+1,y+1,x+6,y+1,1)
                self.oled.line(x+6,y+1,x+8,y+3,1)
                self.oled.line(x+8,y+3,x+8,y+4,1)
                self.oled.line(x+8,y+4,x+6,y+7,1)
                self.oled.line(x+5,y+7,x+1,y+7,1)
                self.oled.line(x+6,y+7,x+9,y+10,1)
                self.oled.line(x+9,y+10,x+9,y+12,1)
                self.oled.line(x+9,y+12,x+6,y+15,1)
                self.oled.line(x+6,y+15,x+1,y+15,1)
            elif text[i]=="C" or text[i]=="c":
                self.oled.line(x+10,y+2,x+9,y+1,1)
                self.oled.line(x+9,y+1,x+4,y+1,1)
                self.oled.line(x+4,y+1,x+2,y+3,1)
                self.oled.line(x+2,y+3,x+1,y+7,1)
                self.oled.line(x+1,y+7,x+1,y+12,1)
                self.oled.line(x+1,y+12,x+4,y+15,1)
                self.oled.line(x+4,y+15,x+8,y+15,1)
                self.oled.line(x+8,y+15,x+10,y+13,1)
            elif text[i]=="D" or text[i]=="d":
                self.oled.line(x+6,y+1,x+9,y+3,1)
                self.oled.line(x+9,y+3,x+9,y+12,1)
            elif text[i]=="E" or text[i]=="e":
                self.oled.line(x+1,y+1,x+9,y+1,1)
                self.oled.line(x+1,y+7,x+7,y+7,1)
                self.oled.line(x+1,y+15,x+9,y+15,1)
            elif text[i]=="F" or text[i]=="f":
                self.oled.line(x+1,y+7,x+6,y+7,1)
            elif text[i]=="G" or text[i]=="g":
                self.oled.line(x+9,y+2,x+8,y+1,1)
                self.oled.line(x+8,y+1,x+4,y+1,1)
                self.oled.line(x+10,y+13,x+10,y+9,1)
                self.oled.line(x+10,y+9,x+6,y+9,1)
            elif text[i]=="H" or text[i]=="h":
                self.oled.line(x+1,y+7,x+9,y+7,1)
                self.oled.line(x+9,y+15,x+9,y+1,1)
            elif text[i]=="I" or text[i]=="i":
                self.oled.line(x+5,y+15,x+5,y+1,1)
            elif text[i]=="J" or text[i]=="j":
                self.oled.line(x+9,y+1,x+9,y+10,1)
                self.oled.line(x+9,y+10,x+7,y+15,1)
                self.oled.line(x+7,y+15,x+3,y+15,1)
                self.oled.line(x+3,y+15,x+1,y+10,1)
            elif text[i]=="K" or text[i]=="k":
                self.oled.line(x+1,y+9,x+8,y+1,1)
                self.oled.line(x+4,y+7,x+9,y+15,1)
            elif text[i]=="L" or text[i]=="l":
            elif text[i]=="M" or text[i]=="m":
                self.oled.line(x+1,y+1,x+5,y+7,1)
                self.oled.line(x+9,y+1,x+5,y+7,1)
            elif text[i]=="N" or text[i]=="n":
                self.oled.line(x+1,y+1,x+9,y+15,1)
            elif text[i]=="O" or text[i]=="o":
                self.oled.line(x+10,y+5,x+8,y+1,1)
                self.oled.line(x+4,y+15,x+7,y+15,1)
                self.oled.line(x+7,y+15,x+10,y+12,1)
                self.oled.line(x+10,y+12,x+10,y+5,1)
            elif text[i]=="P" or text[i]=="p":
                self.oled.line(x+1,y+1,x+7,y+1,1)
                self.oled.line(x+7,y+1,x+9,y+4,1)
                self.oled.line(x+9,y+4,x+9,y+6,1)
                self.oled.line(x+9,y+6, x+6,y+9,1)
                self.oled.line(x+5,y+9,x+1,y+9,1)
            elif text[i]=="Q" or text[i]=="q":
                self.oled.line(x+6,y+10,x+10,y+15,1)
            elif text[i]=="R" or text[i]=="r":
                self.oled.line(x+5,y+9,x+9,y+15,1)
            elif text[i]=="S" or text[i]=="s":
                self.oled.line(x+9,y+2,x+7,y+1,1)
                self.oled.line(x+7,y+1,x+3,y+1,1)
                self.oled.line(x+3,y+1,x+2,y+2,1)
                self.oled.line(x+2,y+2,x+1,y+5,1)
                self.oled.line(x+1,y+5,x+5,y+7,1)
                self.oled.line(x+5,y+7,x+9,y+8,1)
                self.oled.line(x+9,y+8,x+10,y+11,1)
                self.oled.line(x+10,y+11,x+10,y+13,1)
                self.oled.line(x+10,y+13,x+7,y+15,1)
                self.oled.line(x+7,y+15,x+4,y+15,1)
                self.oled.line(x+4,y+15,x+1,y+13,1)
            elif text[i]=="T" or text[i]=="t":
            elif text[i]=="U" or text[i]=="u":
                self.oled.line(x+1,y+1,x+1,y+13,1)
                self.oled.line(x+1,y+13,x+3,y+15,1)
                self.oled.line(x+3,y+15,x+7,y+15,1)
                self.oled.line(x+7,y+15,x+9,y+13,1)
                self.oled.line(x+9,y+13,x+9,y+1,1)
            elif text[i]=="V" or text[i]=="v":
                self.oled.line(x+1,y+1,x+5,y+15,1)
                self.oled.line(x+5,y+15,x+9,y+1,1)
            elif text[i]=="W" or text[i]=="w":
                self.oled.line(x+1,y+1,x+3,y+15,1)
                self.oled.line(x+3,y+15,x+5,y+8,1)
                self.oled.line(x+5,y+8,x+8,y+15,1)
                self.oled.line(x+8,y+15,x+10,y+1,1)
            elif text[i]=="X" or text[i]=="x":
                self.oled.line(x+9,y+1,x+1,y+15,1)
            elif text[i]=="Y" or text[i]=="y":
                self.oled.line(x+5,y+15,x+5,y+7,1)
                self.oled.line(x+5,y+7,x+1,y+1,1)
                self.oled.line(x+5,y+7,x+10,y+1,1)
            elif text[i]=="Z" or text[i]=="z":
                self.oled.line(x+1,y+15,x+9,y+1,1)
            elif text[i]==".":
                self.oled.line(x+1,y+14,x+2,y+14,1)
                self.oled.line(x+1,y+15,x+2,y+15,1)
            elif text[i]=="!":
                self.oled.line(x+1,y+14,x+1,y+15,1)
                self.oled.line(x+1,y+1,x+1,y+10,1)
            elif text[i]=="?":
                self.oled.line(x+5,y+14,x+6,y+14,1)
                self.oled.line(x+5,y+15,x+6,y+15,1)
                self.oled.line(x+5,y+10,x+5,y+8,1)
                self.oled.line(x+5,y+8,x+8,y+6,1)
                self.oled.line(x+8,y+6,x+9,y+2,1)
            elif text[i]=="/":
            elif text[i]==":":
                self.oled.line(x+1,y+6,x+2,y+6,1)
                self.oled.line(x+1,y+5,x+2,y+5,1)
            elif text[i]==",":
                self.oled.line(x+1,y+13,x+1,y+14,1)
                self.oled.line(x+2,y+13,x+2,y+17,1)
                self.oled.line(x+1,y+17,x+2,y+17,1)
            elif text[i]=="&":
                self.oled.line(x+4,y+7,x+2,y+5,1)
                self.oled.line(x+2,y+5,x+2,y+3,1)
                self.oled.line(x+2,y+3,x+3,y+2,1)
                self.oled.line(x+3,y+2,x+4,y+1,1)
                self.oled.line(x+4,y+1,x+6,y+1,1)
                self.oled.line(x+6,y+1,x+7,y+2,1)
                self.oled.line(x+7,y+2,x+8,y+3,1)
                self.oled.line(x+8,y+4,x+6,y+6,1)
                self.oled.line(x+6,y+6,x+1,y+10,1)
                self.oled.line(x+1,y+10,x+1,y+13,1)
                self.oled.line(x+3,y+15,x+6,y+15,1)
                self.oled.line(x+6,y+15,x+9,y+9,1)
                self.oled.line(x+4,y+8,x+10,y+15,1)
            elif text[i]=="+":
                self.oled.line(x+5,y+5,x+5,y+11,1)
                self.oled.line(x+2,y+8,x+8,y+8,1)
            elif text[i]=="-":
            elif text[i]=="=":
                self.oled.line(x+2,y+6,x+8,y+6,1)
                self.oled.line(x+2,y+9,x+8,y+9,1)
            elif text[i]=="0":
                self.oled.line(x+9,y+4,x+2,y+12,1)
            elif text[i]=="1":
                self.oled.line(x+5,y+1,x+2,y+3,1)
            elif text[i]=="2":
                self.oled.line(x+1,y+3,x+2,y+1,1)
                self.oled.line(x+2,y+1,x+7,y+1,1)
                self.oled.line(x+7,y+1,x+9,y+3,1)
                self.oled.line(x+9,y+3,x+9,y+6,1)
                self.oled.line(x+9,y+6,x+2,y+13,1)
                self.oled.line(x+2,y+13,x+1,y+15,1)
                self.oled.line(x+1,y+15,x+10,y+15,1)
            elif text[i]=="3":
                self.oled.line(x+9,y+3,x+9,y+5,1)
                self.oled.line(x+9,y+5,x+7,y+7,1)
                self.oled.line(x+7,y+7,x+4,y+7,1)
                self.oled.line(x+7,y+8,x+9,y+9,1)
                self.oled.line(x+9,y+9,x+9,y+12,1)
                self.oled.line(x+9,y+12,x+7,y+15,1)
                self.oled.line(x+3,y+15,x+1,y+13,1)
            elif text[i]=="4":
                self.oled.line(x+8,y+1,x+8,y+15,1)
                self.oled.line(x+1,y+1,x+1,y+7,1)
            elif text[i]=="5":
                self.oled.line(x+9,y+1,x+1,y+1,1)
                self.oled.line(x+7,y+7,x+1,y+7,1)
            elif text[i]=="6":
                self.oled.line(x+10,y+3,x+8,y+1,1)
                self.oled.line(x+7,y+15,x+10,y+13,1)
                self.oled.line(x+10,y+9,x+8,y+7,1)
                self.oled.line(x+8,y+7,x+4,y+7,1)
                self.oled.line(x+4,y+7,x+2,y+9,1)
            elif text[i]=="7":
                self.oled.line(x+1,y+1,x+10,y+1,1)
                self.oled.line(x+10,y+1,x+3,y+15,1)
            elif text[i]=="8":
                self.oled.line(x+8,y+3,x+8,y+5,1)
                self.oled.line(x+8,y+5,x+6,y+7,1)
                self.oled.line(x+9,y+13,x+9,y+10,1)
                self.oled.line(x+9,y+10,x+6,y+7,1)
                self.oled.line(x+6,y+7,x+4,y+7,1)
            elif text[i]=="9":
                self.oled.line(x+10,y+6,x+8,y+8,1)
                self.oled.line(x+8,y+8,x+3,y+8,1)
                self.oled.line(x+3,y+8,x+1,y+5,1)
                self.oled.line(x+1,y+5,x+1,y+3,1)
                self.oled.line(x+1,y+3,x+3,y+1,1)
                self.oled.line(x+3,y+1,x+8,y+1,1)
                self.oled.line(x+8,y+1,x+10,y+3,1)
                self.oled.line(x+10,y+3,x+10,y+10,1)
                self.oled.line(x+10,y+10,x+9,y+13,1)
                self.oled.line(x+9,y+13,x+7,y+15,1)
            elif text[i]==" ":
                self.oled.fill_rect(x, y, 14, 21, 0)
                pass
        return
    def line1(self, line1text):
        self.display(line1text, [(0,0), (15,0), (30,0), (45,0), (60,0), (75,0), (90,0), (105,0)])
        return
    def line2(self, line2text):
        self.display(line2text, [(0,22),(15,22),(30,22),(45,22),(60,22),(75,22),(90,22),(105,22)])
        return
    def line3(self, line3text):
        self.display(line3text, [(0,44),(15,44),(30,44),(45,44),(60,44),(75,44),(90,44),(105,44)])
        return
    def draw_pixel(self, x, y):
        self.oled.pixel(x,y,1)
#        self.oled.show()
    def draw_line(self, x1, y1, x2, y2):
        self.oled.line(x1,y1,x2,y2,1)
#        self.oled.show()
    def Clear(self):
        self.oled.fill(0)
        self.oled.show()
        return
    def Show(self):
        self.oled.show()
        return
def wrap(string):
    if len(string)> 8:
        spaceArray = []
        cut1 = 23
        cut2 = 23
        cut3 = 23
        for character in range (len(string)):
            if string[character] == " ":
                spaceArray.append(character)
        for i in range (len(spaceArray)):
            if spaceArray[i] < 8 :
                cut1= spaceArray[i]
                #cut[0]=space
            if 8 < spaceArray[i] < 16 :
                cut2=spaceArray[i]
            if 16 < spaceArray[i] < 24 :
                cut3=spaceArray[i]
        line1(string[0:(cut1)])
        line2(string[(cut1+1):(cut2)])
        line3(string[(cut2+1):(cut3)])
    else:
        line1(string)
    #line2(line2text)
    #line3(line3text)
    return
How to use library.
from SSD1306_Large import SSD1306_8x3
display = SSD1306_8x3()
display.Clear()
display.line1('ABCDEFGH')
display.line2('01234567')
display.line3(',!?/:+-=')
display.Show()
Regards
Jim
