Having issues trying to launch a simple command or script via autostart on a Raspberry Pi. The problem is once the command is saved/entered and the Pi is restarted it comes up with a login window, instead of the pi interface(LXDE). Any help would be greatly appreciated.
As mentioned, if you can simply add the @leafpad in the autostart folder first working, we should then be able to run the script successfully! What do you think??
Interesting, problem is the format I have is MP4 which I can convert. What I have noticed as you can see below, that you have to set the permission for the file created before restarting the Pi.
Step 1: Open a terminal session and run raspi-config
sudo raspi-config
Step 2: Select Enable Boot to Desktop/Scratch from the menu and press Enter
Step 3: Select Desktop Login as user pi at the Graphical Desktop.
Step 4: Select and Enter, then select to reboot.
If this doesn’t work for you, you can try:
sudo nano /etc/rc.local
Add the line su -l pi -c startx
before the exit 0 line
Sorry, I guess what I am saying is that his method in the link requires certain type of video format which can be played. My file is a MP4, which will need to be converted. The other question is the Pi at the moment, after a restart will come up to a login screen whereby you cannot login unless you go via terminal. Is there a way to auto login. Thx.
It’s my understanding that the default bootup sequence in Raspian uses on startup is to prompt for a login/password. As you hadn’t changed that setting in your Raspi-Config setup, it’s likely that it’s completely unrelated to the file you are changing.
Guess what, after major download issues, I have managed to download the image onto the SD and no luck – as this version is only works with Raspberry Pi model-2 and below, not model-3 as I have. Not sure if you can still help. Cheers.
Within the step guide, there is an already configured RPiLooper V3 image file which you can download and use. But apparently it is not compatible with the Pi-3 model - other people were also having troubles. What I ended up doing which worked a treat was from the below link.
