It doesn’t seem possible to change my username. Is this correct?
Is there any reason to limit this?
Hi Peter,
You can do that in your account area here (note, you’ll need to be on the “Shop” side of our web platform to see that header information once logged in):
Graham,
I changed it “on the shop side” early yesterday, but the Forum does not reflect this (yet).
Thanks for giving it a go, we’ll check it out. In-between, you should be able to do it here:
I don’t have that option.
Hi Peter,
The forum Core uses has a default max time that people can use to change their username:
From another topic on why it isn’t good to change:
It’s generally a Bad Idea to change usernames. If it’s changed, previous referrals to that user break. That’s why it’s so short.
You might be able to get Core to change it if you send an email through?
Damn, I guess I’ll have to stick with what I’v got
