This is a placeholder topic for “Industrial 8-Channel Relay Module for Raspberry Pi Pico, Multi Protection” comments.
Industrial 8-Channel Relay Module For Raspberry Pi Pico, Power Supply Isolation, Photocoupler Isolation…
Read moreThis is a placeholder topic for “Industrial 8-Channel Relay Module for Raspberry Pi Pico, Multi Protection” comments.
Read moreIndustrial 8-Channel Relay Module for Raspberry Pi Pico. Says Operating voltage 5V. What Amperage?
The relays are quoted as capable of switching 10A at 30V DC.
Relay HLS8L DataSheet (seeeddoc.github.io)
The device is designed for direct interfacing to the Raspberry Pi Pico, so the control inputs will be compatible with the current capability of that device.
Will it work with this SX1262 LoRa Node Module for Raspberry Pi Pico, LoRaWAN | Waveshare | Core Electronics Australia?
SX1262 LoRa Node Module cannot work alone. That one must be connected to a Raspberry Pi Pico first.
Thanks.
My question should have been can I plug the Lora Node Module in along with the Rpi Pico to get LoRa connectivity to control the relays?
Looks like you can. There must not be any problem.
Hi Clint,
It looks like there are a few pin conflicts, unfortunately I don’t think it will be easy to reconfigure the pins on either board.
The clearance might also be a bit tight.
Thanks Liam
Agree with your analysis. Will the following work i.e. plug and play?
It looks like it should be, but I wanted to confirm that this board is compatible with the Pico W as well as the Pico?
Hi Geoff,
Welcome to the forum ![]()
The Pico W’s external pinout is exactly the same as the non-wireless pico with the exception of the onboard LED and the SWD pins, so it should work just fine with this relay module.
