Hello everyone,
I am looking for an inexpensive LiDAR sensor that I can use with a Raspberry Pi computer, that specifically outputs the angle and distance measured. Most sensors I have found seem to only output data to a proprietary file format, that can only be opened to produce an image/display showing a floor-plan-style view of the data. I don’t need that floor plan view; I just need the angle and the distance measured.
Can you please recommend any specific sensor that provides this output?
The range needed is low; anything with 3-4 metres range is fine.
Thank you in advance for your recommendations.
Dave
