Hi, we have an mbot we bought from you, but it now doesn’t drive forward in a straight line. Is this a motor, or other component that we can replace.
It it talked about on the chat boards, but I am not sure what the solution is.
Thanks, Scott
Hi Scott,
This could be caused by an error in your code, a bad motor, or a bad connection to the motor. Check all your connections and see if that fixes the problem. If not, you can get replacement motors here:
There would be some soldering required if you decided to go that route.
