No module named "hailo_rpi_common'
Thanks for that, hopefully they can sort it out
Hey @darrin273365,
We’ve been in contact with our supplier and they have advised on the issues at hand.
The cable extension kits being used are flashed with an old firmware version, and as such are incompatible with the IMX296 (Global Shutter Camera). Unfortunately, the units do not support remote firmware flash. As such, they are happy to provide replacement extension kits, flashed with new firmware. We are happy to organise/facilitate this exchange provided that you are satisfied with this outcome, please advise.
Strangely, the issue with the IMX708 (Pi Camera 3) is unexpected. We have been informed by the supplier that the cable extension kits should work with the IMX708 without issue. We will continue working with the supplier to resolve this issue as soon as possible.
Morning do you know the lead time?
Hey @darrin273365,
Sorry for the late reply!
If you haven’t already, send us an email at support@coreelectronics.com.au so we can continue this process in private, given it pertains to order/RMA information.
Hi!
i have also the problem of the missing hailo_rpi_common file. in the GitHub it is not possible to find it. I saw the old files that the eateries oft this file was removed. I can’t find the other files in /home/admin/hailo-rpi5-examples/basic_pipelines to adjust the resolution of the cam. can I fix this somehow?
Hey @Christoph303621, welcome to the forums!
It’s been a while since I’ve toyed around with the AI Hat, and they have definitely shuffled the structure of it since we released the video. From memory, there is a file somewhere in there somewhere that contains that information; it may not be called basic_pipelines anymore, and may be a folder higher or lower. This is, unless they have changed it yet again in the last few months :sob:.
I would recommend having a dig around, let us know if you can find it!
I finally found it…
/home/admin/hailo-rpi5-examples/venv_hailo_rpi_examples/lib/python3.11/site-packages/hailo_apps/hailo
thanks
Very nice sluething!
