Put on a sturdy and beautiful enclosure for your electronic project! This project box is made from high-quality ABS material, and the surface of the enclosure is…
I bought this because I wanted to mount some potentiometers onto it.
My vision is to have a box I can pull out at any time with a little row of four pots and cables coming out the side for quick access while prototyping.
I’ve just drilled some holes into the lid and the pots hang there just fine.
I’m wanting to pass the input and output from the side. I guess I could just drill a big hole and pass an ugly bunch of cables out. What would be better is some kind of header pins I could somehow attach to the side of the box?
I figure I can’t be the first person to want to push some cables in and out of a project box.
Is there a better way?
How would you approach passing cables through a project box like this?
Decided to start with just two.
Figured I was bound to make some mistakes and learn some lessons.
I’ll try again some day with four pots and some cleaner wiring.
