I have the script below running ok out of Thonny.
from gpiozero import Button
from PiicoDev_Unified import sleep_ms
from PiicoDev_Servo import PiicoDev_Servo, PiicoDev_Servo_Driver
# Initialise the Servo Driver Module
controller = PiicoDev_Servo_Driver()
# Simple setup: Attach a servo to channel 1 of the controller with default properties
servo_1 = PiicoDev_Servo(controller, 1)
servo_2 = PiicoDev_Servo(controller, 2)
servo_3 = PiicoDev_Servo(controller, 3)
servo_4 = PiicoDev_Servo(controller, 4)
# Customised setup - Attach a servo to channel 1 of the controller with the following properties:
# - min_us: the minimum expected pulse length (microsecconds)
# - max_us: the maximum expected pulse length (microsecconds)
# - degrees: the angular range of the servo in degrees
# Uncomment the line below to use customised properties
# servo = PiicoDev_Servo(controller, 1, min_us=600, max_us=2400, degrees=180)
print("x1 ")
inc_1 = 5
# Start positions
angle_1 = 130
servo_1.angle = 130
angle_2 = 100
servo_2.angle = 100
angle_3 = 20
servo_3.angle = 20
angle_4 = 0
servo_4.angle = 0
print("x2 ")
def joint_1_add():
global angle_1
angle_1_old = angle_1
angle_1 = angle_1 + inc_1
if angle_1 >= 180:
angle_1 = 180
print("1 " + str(angle_1))
for x in range(angle_1_old,angle_1,1):
servo_1.angle = x
sleep_ms(100)
def joint_1_sub():
global angle_1
angle_1 = angle_1 - inc_1
if angle_1 <= 0:
angle_1 = 0
for x in range(angle_1_old,angle_1,-1):
servo_1.angle = x
sleep_ms(100)
button_1 = Button(pin=17,bounce_time=0.05)
button_2 = Button(pin=5,bounce_time=0.05)
button_1.when_pressed = joint_1_add
button_2.when_pressed = joint_1_sub
print("x3 ")
def joint_2_add():
global angle_2
angle_2_old = angle_2
angle_2 = angle_2 + inc_1
if angle_2 >= 180:
angle_2 = 180
print("2 " + str(angle_2))
for x in range(angle_2_old,angle_2, 1):
servo_2.angle = x
sleep_ms(100)
def joint_2_sub():
global angle_2
angle_2 = angle_2 - inc_1
if angle_2 <= 0:
angle_2 = 0
for x in range(angle_2_old,angle_2,-1):
servo_2.angle = x
sleep_ms(100)
button_3 = Button(pin=22,bounce_time=0.05)
button_4 = Button(pin=27,bounce_time=0.05)
button_3.when_pressed = joint_2_add
button_4.when_pressed = joint_2_sub
print("x4 ")
def joint_3_add():
global angle_3
angle_3_old = angle_3
angle_3 = angle_3 + inc_1
if angle_3 >= 180:
angle_3 = 180
print("3 " + str(angle_3))
for x in range(angle_3_old,angle_3,1):
servo_3.angle = x
sleep_ms(100)
def joint_3_sub():
global angle_3
angle_3 = angle_3 - inc_1
if angle_3 <= 0:
angle_3 = 0
for x in range(angle_3_old,angle_3,-1):
servo_3.angle = x
sleep_ms(100)
button_5 = Button(pin=6,bounce_time=0.05)
button_6 = Button(pin=19,bounce_time=0.05)
button_5.when_pressed = joint_3_add
button_6.when_pressed = joint_3_sub
print("x5 ")
def joint_4_add():
global angle_4
angle_4_old = angle_4
angle_4 = angle_4 + inc_1
if angle_4 >= 180:
angle_4 = 180
print(angle_4)
for x in range(angle_4_old,angle_4,1):
servo_4.angle = x
sleep_ms(100)
def joint_4_sub():
global angle_4
angle_4 = angle_4 - inc_1
if angle_4 <= 0:
angle_4 = 0
print(angle_4)
for x in range(angle_4_old,angle_4,-1):
servo_4.angle = x
sleep_ms(100)
button_7= Button(pin=25,bounce_time=0.05)
button_8 = Button(pin=24,bounce_time=0.05)
button_7.when_pressed = joint_4_add
button_8.when_pressed = joint_4_sub
print("x6 ")
There is no apparent while loop but I assume there is one behind the scenes.
I want it to run on startup and have added this line to rc.local
python3 /home/gjc/mikado/robot.py &
my script runs because it implements the startup positions near the beginning of the script.
However, the buttons do not work.
Any clues on why please?
The Pi will be at the top of a 15 metre mast so it will be running headless.
