Hi, I would like help to get my raspberry zero to transmit a signal (character) to my arduino in order to trigger a servo motor. I am using XBee series 1, API mode for all XBee units. I have tested the wireless communciation via Xbees between two arduino units and they work fine, with the activation of the servo motor. The problem arise when I try to use Xbee communication with a raspberry zero (with a xbee USB explorer) together with an arduino. I appreciate if I can get advice on how I can overcome the lack of XBee transmission from my rapsberry zero to my arduino. Thanks!
The code of my sending unit (raspberry zero) is:
import serial
ser = serial.Serial('/dev/ttyUSB0', 9600, timeout=.5)
for x in range(0,10):
ser.write('A\r\n')
The code for my receiving unit (arduino) is:
#include <Servo.h>
#include "SoftwareSerial.h"
Servo myservo;
int pos = 0;
SoftwareSerial XBee(2, 3);
void setup()
Serial.begin(9600);
XBee.begin(9600);
myservo.attach(12);
void loop()
if (XBee.available())
char c = XBee.read();
if (c == 'A')
//delay(7000);
myservo.write(180);
delay(3000);
else
delay(10);
To rule out an Xbee problem, I also did another test setup and used another arduino as the sending unit.
This worked and the code for this arduino unit is:
void setup()
Serial.begin(9600); //Start serial port for debugging
XBee.begin(9600);
delay(2000);
void loop()
XBee.write('A');
delay(4000);
Serial.println("A Sent");
