RS232 Serial Converter (CE04442) Logic Levels
Just had a very quick play.
This setup is
PC → USB-RS232 → Lora Unit → over air → 2nd Lora Unit → RS232-USB → PC
Buad 9600 8 data bits no parity 1 stop bit, (I cant remember what the default is as these will be as per when I last played).
With this setup Its working in stream mode, so what ever I TX on one will appear on the other. e.g. On my PC I can have two putty windows open (one on each unit) what ever I type into one putty appears on the other and visa versa.
The key post from that thread (from me) would be
I.e. In this unit and setup.
USB RS232 TX - Lora RX and RX → Lora TX
i.e. 2-3 and 3-2 with ground 5-5
Just to be clear, here is a photo of a quick test wire up. Keeping in mind a proper connection would be better, this is a quick test to clearly show what pin connected to what pin.
