Hi Donald, Jane
I am currently looking at the diagrams (Fritzing ??) on Core site for the DfRobot device you kinked.
Here is the first copied straight from that page
This is pretty self explanatory.
3 inputs. 5V solar panel IN, USB 5V charge IN and 3.7V Li Battery IN ( Green block and JST). Note these are all marked as INPUTS with the OUTPUT being regulated 5V, both USB and 3 headers for other uses.
Now this leads me to believe that your LOAD connection to the green blocks could be incorrect. This is an input for conversion to 5V and an output to suit charging 3.7V cells which ever is appropriate at the time.
This is backed up by the third image
This clearly shows the terminal block and JST inputs labelled as 3.7V cell “OR” DfRobot battery but NOT BOTH at the same time.
This looks like that once again a device is trying to be used in a manner that it is not designed for.
While we are here it is worth noting the conversion efficiencies
- Regulated Power Supply Efficiency (3.7V battery IN): 86%@50%Load
- USB/solar charge efficiency: 73%@3.7V 900mA BAT IN
Not the most efficient kid on the block but convenient and looks easy to use so maybe worth the trade off.
Donald, Jane. Add on to this scenario:
Having a few more thoughts here.
It is quite possible that your proposed connection to the load to the green terminal block may work. I would need to see a schematic to comment definitely but here are a couple of thoughts.
I assume the green block and JST are connected together in parallel.
While the solar and USB inputs are not suppling charging power the battery will be providing power to the 5V output and in your case the loads it is connected to the green block.
If the solar IN and/or the USB charging IN are powered the JST (and green block) should go into Charging mode and output charging power to the JST and Green block to charge the LiPo cell.
In this situation the voltage at the LiPo (and load) could be up to 4.2V to charge the connected cell. But only at the max current (900mA I think) that this charging system will provide. If the load current and charging current exceed this you will have a problem.
Now I don’t know how well this 4.2V would be tolerated by your load. Might be OK as a fresh cell would be 4.2V for a while. There again it might not.
I am not about to find out either as I am not likely to attempt this configuration at this time so will leave this up to you. I don’t have the parts anyway but will leave you with these thoughts for you to consider. Might give you some ideas.
