Hi all, I’m working on my first electronics project and I’d appreciate a sanity check from people who know what they’re doing.
The goal is to build a lamp that runs entirely from a solar panel, controlled by a Raspberry Pi Pico 2WH. I’m aiming to keep everything no-solder if possible (as I don’t have tools or experience) but could find a maker space for this if you think it’s important.
The light itself will be a WS2812B LED strip (though I’ll probably only be driving a handful of pixels at a time to reduce power draw). The Pico will handle scheduling, colour control and brightness (my idea is to have the light follow the sunrise-sunset of another time zone). The solar panel will be outdoors on the roof, and the battery plus electronics will live indoors, so I figure I’ll daisy chain DC extension cables between the two.
Here’s the full parts list I’ve put together:
Adafruit USB/DC/Solar Li-ion charger v2
Voltaic P110 10 W 5 V solar panel
DC extension cable (5.5 mm × 2.1 mm)
Panel plug adapter (3.5 mm to 5.5 mm)
2×18650 battery holder
Two 18650 Li-ion cells (3.7 V, 2600 mAh each)
1 m WS2812B strip (144 LEDs/m)
3-pin LED strip connector cable
1000 uF electrolytic capacitor
Logic-level shifter (3.3 V to 5 V)
300-point solderless breadboard
Jumper wire sets (M/M, M/F, F/F)
USB-A to micro-USB cable to power the Pico from the charger
I believe this collection of parts should all play nicely together, but since I’m new to this I’d love to know if there’s anything obviously missing, any easier alternatives, or any places where I’m making things too complicated.
One question I’m not fully confident about is the power side: is a 10 W panel feeding two 2600 mAh 18650s enough for running a Pico plus a small number of WS2812B LEDs for ~6 hours per day?
Any feedback or warnings would be very welcome.
