This is a placeholder topic for “SparkFun QwiicBus - EndPoint” comments.
The SparkFun QwiicBus EndPoint is the fastest and easiest way to extend the range of your I2C communication bus. The breakout uses NXP’s PCA9615 IC, which converts…
Read moreThis is a placeholder topic for “SparkFun QwiicBus - EndPoint” comments.
Read moreThis looks really useful (extending i2c over Ethernet cable), so am looking for some feedback or review. I note the endpoints are currently out of stock while midpoints are in stock - so someone must have bought some !
Hey there, @Donald23173,
I haven’t used this product personally, but anytime you switch from serial communication to a longer range form, you’re going to be able to get some much greater distances (Sparkfun quotes up to 30m, but I would not be surprised if you can get longer).
Instead of measuring to ground, like in I2C, which leaves it very vulnerable to noise and capacitance, the receiver measures the voltage difference between the two wires in each pair. Noise on the line would then affect both wires simultaneously, and since you’re measuring off the difference in voltage between them, the noise does not interfere with the underlying signal.
Hi Nicholas
A copy of a bit of an article on Wikipedia
It is generally accepted that RS-485 can be used with data rates up to 10 Mbit/s[a] or, at lower speeds, distances up to 1,200 m (4,000 ft)
Make what you will from that but I think this device would be the go for anything over a few metres.
For what it is worth O am a great fan of balanced systems. Been used for Audio for donkeys years and I have found it saves a lot of bother in the grand scheme of things.
There is a very good reason why Broadcast and TV and the like use it exclusively.
